Old 05-14-2014, 08:42 PM   #1
Kyle1228
Kyle1228's Avatar
Drives: 2014 Camaro 2LS Summit White
Question Can I put quad tips onto the pypes cat back exhaust?
I'm looking into buying the pypes cat back exhaust for my '14 2ls, but i want to know if ill be able to put the quad tips i bought from ssclones on. or will they not fit because the exhaust won't line up with the center of the npp diffuser?
by the way i found the exhaust for $517 on summit racing. its for the v8 but its exactly the same as the v6 version besides 4.5" tips.
Kyle1228 is offline   Reply With Quote
Old 05-14-2014, 08:44 PM   #2
Dave1222
Drives: 2010 CAMARO SS/RS
Wow that seems super reasonable....
Sent from my iPad using Tapatalk
Dave1222 is offline   Reply With Quote
Old 05-14-2014, 08:56 PM   #3
Kyle1228
Kyle1228's Avatar
yeah. same one on phastek is 700 bucks. Im pretty sure thats what im gonna get no matter what, just want to know if i can put my quads on.
Old 05-14-2014, 09:00 PM   #4
Dave1222
I am no expert but I am pretty sure you can just have a muffler shop weld the tips on
Sent from my SPH-L710 using Tapatalk
Old 05-14-2014, 09:03 PM   #5
newagemuscle
Philippians 4:13
newagemuscle's Avatar
Drives: SLP Supercharged LS3
if it's anything like mine yes, here's what I did.
http://www.camaro5.com/forums/showthread.php?t=343362
newagemuscle is offline   Reply With Quote
Old 05-14-2014, 09:04 PM   #6
Kyle1228
Kyle1228's Avatar
Thats what i figured I just wanted to know. Couldnt really find an answer anywhere. Thanks for your input.
Old 05-14-2014, 09:07 PM   #7
Kyle1228
Kyle1228's Avatar
Ok great!! Thanks. The ssclones tips look so badass, been looking at them everyday since i got them lol. now just have to pull the trigger on the exhaust
Old 05-14-2014, 09:30 PM   #8
mr02Z/28
Drives: 2002 Z/28,1968 Chevelle convert.
I just installed my Pypes system on 2013 2LT 3.6L .... I have to tell you it sounds really good, the problem I am having is that the clearances are way to tight where the pipes come too close to the chasis and I am getting quite a bit of chatter ... The pipes are rubbing against parts of the underneath but I bought some insulating pads to see if that eliminates that noise ....
mr02Z/28 is offline   Reply With Quote
Old 05-14-2014, 09:47 PM   #9
Kyle1228
Kyle1228's Avatar
Well hopefully that will solve it for you, or it could be that it was just installed slightly off. I saw on another thread that it was close, just needed adjusting.
Just ordered mine, its not gonna ship for 3 weeks....
Old 05-15-2014, 10:04 AM   #10
bionick
bionick's Avatar
Drives: 2010 2SS/RS M6
Yeah I just put my quad tip diffuser on yesterday and I have the SLP LM2 axle back and I had a really hard time getting the tips to lineup. The tips are what a lot of other members on here use which is why I purchased these ones. First I tried doing the rear right exhaust tip and it seems like no matter what I did it would basically be touching the diffuser on the right side and then there would be about an inch of Clarence on the other side so it looked pretty stupid plus I don't want the diffuser getting burnt. I'm sure if I go to a muffler shop they can bend my pipe on the muffler that connects to the tips, but I was hoping to just be able to do it all myself
2010 Camaro 2SS/RS | 416 LS3 | FED stage 2 heads
bionick is offline   Reply With Quote
Old 05-15-2014, 11:13 AM   #11
ksspeed
ksspeed's Avatar
Drives: 2013, Camaro 2LS (BRM)
I have the pypes exhaust on my car and ran into the same problem, what i did was loosen the clamps a little, and pulled down on the exhaust enough to tweak it, then stuck a pry bar between the body and exhaust and tightened it and removed the pry bar, turned out great.
BBK cai, vmax ptb, pypes cbe, nos N2o (50 shot wet), nytrex spacer plate, bmr drive shaft loop, rx catch can.
ksspeed is offline   Reply With Quote
Old 05-15-2014, 03:20 PM   #12
mr02Z/28
I tweaked it like that too but the rattle still existed a bit, but now today, I just installed a "Heat Shield Product" Inferno Shield between the tunnel brace/muffler area and that did the trick ...... no more creaking and rattling ....... yay .......
I really have to say that I am a big fan of the Pypes system and the way it sounds, I didn't think it would sound as good as it does and I only paid $5xx something for mine ..... For the price it is wonderful .... at wide open throttle it sounds so sweet, my kids are even impressed
Old 05-15-2014, 04:19 PM   #13
ksspeed
ksspeed's Avatar
Yeah, i didnt want an exhaust that claimed to sound like a v8, so i checked out pypes, i like it, at idle and part throttle it reminds me of a ricer a little, but at wot, it sounds freekin awsome.
Old 05-15-2014, 07:13 PM   #14
Kyle1228
Kyle1228's Avatar
Thanks for all the input guys. Ill figure it out whenever it gets here.
lfx exhaust, lfx performance, v6 exhaust
