Old 05-16-2014, 09:58 PM   #1
Insaniak
Drives: 2010 LT
MRT Install problems..
So I cut the stock muffler off 3.5 inch and well my problem is MRT doesnt even slide over the pipe its the same exact size... Thats my problem.
Insaniak is offline   Reply With Quote
Old 05-16-2014, 10:11 PM   #2
kjkjr27
COTW 9/16/13
kjkjr27's Avatar
Drives: 2011 2LT/RS Camaro IOM
The ends might have gotten bent try bending them out with a mallet and see if that helps any, I had to do that with one of mine.
kjkjr27 is offline   Reply With Quote
Old 05-16-2014, 10:30 PM   #3
Insaniak
Drives: 2010 LT
Well I tried that. The ends are ment to be flared, but I do not have a tool to flare them out. The thing is its like that for both MRT Mufflers. Im not sure what the deal is with these ones.
Old 05-17-2014, 04:50 AM   #4
rtcat600man
having FUN now 13.66@101
rtcat600man's Avatar
Drives: 2010 2LT IOM
Try a large pair of vice grips, or channel locks, or large adjustable wrench to pry it back a 1/16" I know it is extremely hard to do as I had to do it on one of mine to. Other option is take it to a local muffler shop and have them flair it open. they have hydraulic tools that can do it easily.
Old 05-17-2014, 10:10 AM   #5
Insaniak
Drives: 2010 LT
Are those ends stainless steel? I talked with muffler guy and he said if it's stainless it would probably split
Old 05-17-2014, 01:22 PM   #6
scrming
Red Brick of Vengeance!
scrming's Avatar
Drives: 12 Second Brick
They are stainless. Are there slots cut in them? And even though it is stainless it can still be expanded some
scrming is offline   Reply With Quote
Old 05-17-2014, 05:55 PM   #7
MDcarnut
Drives: 2013 IOM 2LT RS
They are not the same size. It seems like it but they are not. It is a very tight fit, I struggled with it for a while. Thought about giving up but kept working and finally got it. I did it all by myself but it might help you to have someone with you. File the ends that you sawed to get them as smooth as possible. Fit it as best you can, use force and turning motion and work it on there. I do not recommend any hammering with anything unless you can see something is clearly out if round.
MDcarnut is offline   Reply With Quote
Old 05-18-2014, 04:36 PM   #8
stevey_frac
Drives: 2010 LT2/RS Coupe
It helped me to spray just a dab of WD-40 on the ends of mine. Then it slipped on, much easier.
Mods so far:
MRTv2 Exhaust
275 / 40 / 20 Continental ExtremeContact DW's on all corners
Next up:
Magnaflow Resonated X-Pipe (Purchased but not installed)
EBC Redstuff street pads
Carbotech XP8 / XP12 track pads
1LE Track Pack
Note: This car built by JDP Motorsports!
stevey_frac is offline   Reply With Quote
Old 05-18-2014, 10:25 PM   #9
Insaniak
Drives: 2010 LT
I just used vice grips clamp tightening just moved it back In place but man whatdifference after that it was easy to install. They should say something about using vice grips or what not... They make it sound so easy.. Haha I love em I do notice the drone at 70+mph it bothers me some but I'm not worried about it
Old 05-18-2014, 10:38 PM   #10
AnUnarmedMan
AnUnarmedMan's Avatar
Drives: 2013 LS
Buy the xpipe and some hush mats. Also after a month it levels out and sounds even better.
AnUnarmedMan is offline   Reply With Quote
Old 05-19-2014, 05:50 PM   #11
PieNsky
PieNsky's Avatar
Drives: Victory Red 1LS
Stainless Works went from a X pipe to more of a H pipe as the harmonics are worse with the X pipe.
PieNsky is offline   Reply With Quote
Old 05-19-2014, 05:55 PM   #12
PieNsky
PieNsky's Avatar
I think backing into my carpool's drive for four years flexing the X pipe broke mine. His driveway was too steep to pull in and I scrapped the first and only time I pulled in. A muffler shop should know what to do, but I agree, it should have been mentioned before purchase.
Old 05-19-2014, 06:16 PM   #13
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
To expand the ends to the MRTs, I just stuck a larger flat head screw driver in the slots that are cut on either end and hit it with the hammer.
