![]() Join Date: May 2014
Gas for v6?
I have been using the premium gas in my car sense I got it. However I was reading the owners manual and it say I should be using the regular 87 gas due to having the 3.6L v6. Should I switch to the regular? what is the difference between the way it burn for a v6 and v8?
Sent from my SCH-I545 using Tapatalk |
KaBoom1701
Welcome to the site.
This has been discussed many times before here. I suggested using the search feature. But to answer your question I've always put 91+ in my car. Some will say it's a waste but it's your ride and investment. Take care of it.
Mods:
I think 87 is safest because if it runs too rich, it can definitely diminish the performance and gas mileage. But I don't know. The v6 is rated at 87, so I'd assume it's best to use what the people who made the car say it needs. I'm sure you're fine though!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 camaro Join Date: Feb 2012
and once again, the 87 is what GM says is the minimum octane gas you should burn. you can continue to use it, or go higher. a higher octane does improve the performance, but probably (outside of a track) nothing you would notice in daily driving.
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
Run high octane. Be impressed when dyno tuning.
#6 |
The Logistician
Drives: 2012 LFX 45th Anniversary Join Date: Aug 2012
You do not have to use premium, but it's probably better for your car if you do. With knock sensors and all the other computers premium isn't required. You should have slightly better performance and less fuel consumption with premium. If I could stomach the extra cost I'd put premium in mine.
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Premium is what, 30-40c more/gallon? That translates to about 8 dollars more over regular on a BONE DRY tank.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
#8 |
Burn whatever you feel like paying for. Personally, when I had my V6 it ran just fine on 87 - couldn't tell any difference when occasionally burning higher octane. Continuous use of high octane might make a difference... but I doubt it. Just MHO.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
#9 |
#10 |
I hear ya. It's not that it's all that much more costly... just a question if you're paying for any gain or not. If not (and I'm not saying "no gain" 'cause I don't know) why spend it. That would be like buying a six-pack and then just pouring it out on the ground. A pointless waste of money.
#11 |
![]() Drives: 2010 Camaro 2SS Black Join Date: Jun 2013
Place more of an emphasis on top tier gasoline than octane.
#12 |
![]() Drives: 2012 LS Join Date: Apr 2013
#13 |
Dimitri
Drives: 68 GTO 455 Ram Air; 2014 Camaro ZL1 Join Date: Jan 2014
Preignition is caused by running premium fuel in a engine that is designed to run on low octane. The compression ration in your v-6 is too low to combust premium fuel completely. Running premium fuel will cause your ECU to pull timing because it is knocking. You will not feel this or hear this knock. This will also cause greater carbon build up in your combustion chamber.
#14 | |
![]() Drives: 2018 Camaro 2SS, Garnet Red Join Date: Jan 2014
These engines have 11.5 to 1 Compression Ratio, it can run 87 but works better with 91/93. Which is why there are performance tunes for 91/93 and none for 87. http://www.camaro5.com/forums/showthread.php?t=340198 Theres the thread with a bunch of info regarding this debate in the LFX forum. |
