![]() ![]() Drives: 2010 2SS Join Date: Sep 2012
SOLD! Hurst Billet Plus Shifter /w white retro knob 10k miles
will upload a pic shortly when phone is done charging :P i changed to mgw shifter. shifter has around 10k miles on it. 100$ shipped.
2010 2SS- 562whp/634wtq 12 psi on3 turbo 78mm magnum /w aem truboost, pat g cam, Kooks 3" catback, Factory Rep 41s with 285/315 20" michelin PSS, Snow Meth, Hex Hood Vents, ZL1 FP & ADM FPCM /w JMS BAP, ID 850s, DSS lvl 4 axles & aluminum 1 piece D/S, Total Pro BMR bushings, fe4 sways, toe rods & trailing arms, Prothane engine mounts, MGW shifter, eaton true trac, mantic 9000 clutch, idealg master cylinder, JDP clutch oil reservoir, ram clutch pedal adjust, Tick clutch & bleed lines, Dewitts Rad
![]() Drives: Black LS Join Date: Mar 2014
Pm sent
![]() Drives: 2010 camaro ssrs Join Date: May 2014
Do you still have the shifter?
Sent from my SCH-I605 using Tapatalk |
