Old 05-17-2014, 01:46 PM   #1
NJBourne23
Master of Nothings
NJBourne23's Avatar
Drives: 2010 Chevy Camaro 2LT/RS
PA inspection question
So I was told certain counties do not require emissions. I live in Montgomery County where they require inspectors to test for that but if I went north by the Poconos they can pass my car legally with LT headers and high flow cats etc?
2010 Chevrolet Camaro 2LT/RS
NJBourne23 is offline   Reply With Quote
Old 05-17-2014, 01:52 PM   #2
rusn63@yahoo.com
Drives: 10 Camaro SS
no, the state goes by where the car is registered (county).
rusn63@yahoo.com is offline   Reply With Quote
Old 05-17-2014, 02:15 PM   #3
kream88
Drives: 2010 Chevy Camaro 1SS RS
I believe if you drive less then 5000 miles a year they can just exempt your emissions.
kream88 is offline   Reply With Quote
Old 05-17-2014, 08:40 PM   #4
kmm1412
The Bolt-On Beast
Drives: 2011 2SS/RS IBM w/CGM Stripes
If you do not drive your car more than 5000 miles a year, you can get an exemption sticker. I have one on my car. You must get it inspected in the same month every year though. If you are going for an exemption sticker, you can't get your car inspected earlier than your sticker month, unlike if you are going for a regular emissions inspection, which you can get done a month or two earlier than the month on your sticker. The county in which your car is registered, and its current inspection requirements, is the basis for your car's emissions inspection rules, not where you take it in the state.
kmm1412 is offline   Reply With Quote
Old 05-17-2014, 09:07 PM   #5
NJBourne23
Master of Nothings
NJBourne23's Avatar
damn, thanks thought I had a loop hole
Old 05-17-2014, 10:34 PM   #6
Archonlord
Archonlord's Avatar
Drives: 2010 Black 1LT
I pass PA emmisions testing with LT headers and hi flow cats
BBK LT Headers, Injen CAI, PYPES cat back, Trifecta Tune,
Mike Norris Catch Can, Whiteline sways, end links and subframe bushings
Archonlord is offline   Reply With Quote
Old 05-18-2014, 12:20 AM   #7
kmm1412
The Bolt-On Beast
I have been told by my tuner that I would have no problem passing emissions either with LT headers and high flow cats. I don't drive my car more than 5000 miles a year anyway, so I just request the exemption sticker.
Old 05-18-2014, 07:26 AM   #8
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
+1
Also, in PA from what I've been told by two shops, one being a dealership, there aren't places that do a sniffer test. As long as you still have cats you should be fine.
Check out my build thread
Old 05-18-2014, 09:58 AM   #9
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
I also live in Montgomery County.
As long as you aren't pushing a CEL for anything emissions related, and visually still have Catalytic Converters (basically it can't LOOK like you've removed anything that is emissions related), even if you did remove it, it can't look like it.
They just hook your car's OBD2 port up to their computer and make sure all of the sensors are reporting the correct ready reading. Done and done. We aren't hooked up to sniffer's or anything around here.
Due to extensive Mods, my Monte Carlo would never pass, so I keep it under 5000 a year and get the exemption haha. But I did use HPTuners on my car when it did need the inspection to turn off the CELs and never report them.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 05-18-2014, 11:42 PM   #10
ChocoTaco369
145lb Powerlifter
ChocoTaco369's Avatar
Drives: 2013 Camaro 2SS RS LS3
You will pass with LT headers and cats as long as you have the codes deleted with a proper tune. My 4th gen would pass all the time before it blew up. They simply check for cats under the car with a mirror and scan the computer to verify it isn't throwing any codes. I live in Lower Merion, no problems ever.
NJ was even easier when I lived there. Every other year, free at the state facilities. PA and their ridiculous annual inspection BS...
ChocoTaco369 is offline   Reply With Quote
Old 05-19-2014, 09:06 AM   #11
ChibiBlackSheep
If you do have the codes being thrown and preventing you from passing, shoot me a PM. I can probably help you with a tune.
Old 05-19-2014, 10:52 AM   #12
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
I never knew that you had to get the inspection in the same county as the car was registered in. Are you sure that is true? I live in close to the border of Lancaster and Berks Counties. I live in Lancaster County, what if I took it to garage in Berks County, wouldn't they inspect it?
sscamaro is offline   Reply With Quote
Old 05-19-2014, 10:58 AM   #13
ChibiBlackSheep
You can go to any county and get it inspected, they just have to follow the laws of the county it is registered in.
I used to live in Pike County, PA. Didn't require emissions. I would get it inspected in Montgomery county and they didn't have to worry about emissions testing, because that was based off of the registration county.
Now that I officially moved my county on my registration, I have to get it emissions inspected.
Old 05-19-2014, 09:16 PM   #14
TeelsBlack
TeelsBlack's Avatar
Drives: 2013 Black-on-Black 2SS/RS
I'm gonna guess once I put my cams in, I'm gonna have issues with the inspection? I'm not originally from pa
Edit:lycoming county btw
TeelsBlack is offline   Reply With Quote
