Old 05-18-2014, 08:03 AM   #1
Bigjk47
Bigjk47's Avatar
Drives: 2010 SS Camaro Automatic
Swapping 4 Pack Gauge Cluster
I have a 2010 SS and my wife has a 2010 RS. My Camaro just has the little flat storage din ,She has the gauges. I would rather have the gauges and she would rather have the din. I have done some research and seems to be an easy swap but cant find a solid answer on wiring. My question is do I need a plug n play cable or is hers able to come out and just swap everything with out purchasing anything else? Thanks in advance for any help!
Bigjk47 is offline   Reply With Quote
Old 05-18-2014, 08:24 AM   #2
Smokey jr.
Drives: 2011 inferno orange camaro
contact Ofer at gen5diy...the best answer you will get
Smokey jr. is offline   Reply With Quote
Old 05-18-2014, 09:01 AM   #3
justjoshin
justjoshin's Avatar
Drives: 2010 SW 1SS L99 Camaro
Is her car a SS? Do they have the same transmissions?
justjoshin is offline   Reply With Quote
Old 05-18-2014, 09:13 AM   #4
Bigjk47
Bigjk47's Avatar
No hers is a V6 RS . And mine is l99 SS. But hers also has 6 speed tiptronic trans. Not sure if it is the exact same trans though.
Old 05-18-2014, 09:49 AM   #5
justjoshin
justjoshin's Avatar
same part number for the V6 & V8 #92247189
Old 05-18-2014, 09:56 AM   #6
Bigjk47
Bigjk47's Avatar
Ok, thanks for checking, I sent gen5diy a message too so we will see. Its not that big of a project so Ill probably just pop it apart and check it out. Just thought I might be able to find an answer before I tore into it.
Old 05-18-2014, 10:00 AM   #7
justjoshin
justjoshin's Avatar
I was recently looking into this as well. 3 part #'s (1:V6&V8 Auto, 2:V6 manual, and 3:V8 manual). So from what I see it should swap out.
Old 05-18-2014, 10:23 AM   #8
Bigjk47
Bigjk47's Avatar
ok cool thanks again man. Ill repost after I give it a shot today.
"All Hustle, No luck!"
4pack, diy, gauges
