Old 05-18-2014, 02:35 PM   #1
SERVED_USMC
SERVED_USMC's Avatar
Drives: Slow
PS pump whining. Fluid full.
Pump was completely drained when I replaced the motor. I filled the pump before first start up. Reservoir is full but the pump still whines while turning and the wheel is very choppy. Almost like I have air in the lines. Is there any way to bleed the system to the and fix it?
SERVED_USMC is offline   Reply With Quote
Old 05-18-2014, 03:53 PM   #2
SERVED_USMC
Drives: Slow
I think I found the answer to what I need to do with working the air out of the lines. Now to see if it actually works.
Old 05-18-2014, 06:45 PM   #3
L99CAMA2011
L99CAMA2011's Avatar
Mechanics usually recommend turning the wheel left full turn then right and repeat a few times to get the air out. Also fill it with Redline powersteering fluid for added protection.
