Old 05-18-2014, 11:56 PM   #1
keving2873
keving2873's Avatar
Drives: 2011 Camaro 2SS RS
Question Apex Catch Can Question (Pictures included)
So I was unscrewing the bottom assembly to check on how much oil had been caught and ultimately empty my catch can. When I pulled out the bottom portion, it was accompanied by more than what I was expecting. I am guessing this is the filter that came out but this is about the 3rd time I have opened it up to check the level and this part has never come out before. Is this a bigger problem or did something just get loose?
2023 Black ZL1 **Awaiting Allocation**
476whp 455trq / Tuned by Tom Wong
CAI Intake with ADM Scoop, Borla ATAK cat-back, ARH 1 7/8 Headers and HF Cats
Custom Comp Cam 231/234 114LSA 617/598 lift, Katech timing chain
Apex Catch-can
VMAX Ported Throttle Body
20" Niche Essen's wrapped in Michelin PSS 315/295
keving2873 is offline   Reply With Quote
Old 05-19-2014, 07:45 AM   #2
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
That is the filtration chamber. You just need to screw it back into the upper portion of the can good and tight.
Old 05-19-2014, 11:14 AM   #3
keving2873
keving2873's Avatar
That's what I was hoping. Thanks, Chase!
Apex Catch-can
Old 05-19-2014, 01:13 PM   #4
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
Had same happen. After screwing the condensing chamber in tightly, has not recurred.
wakespeak is offline   Reply With Quote
Old 05-19-2014, 01:19 PM   #5
keving2873
keving2873's Avatar
Thanks for the feedback. Must have just shaken it loose with all the rocking around...
Apex Catch-can
Old 05-19-2014, 01:35 PM   #6
Apex Motorsports
apex, catch can, oil
