Old 05-19-2014, 11:38 AM   #1
SSTG
Drives: 2014 Z51 Corvette
Lower bumper removal?
Does anyone know if the whole front bumper needs to come off to replace the lower section? Part # 22894223
It shows it's held on by 12 bolts? Could it be that easy?
Thanks!
SSTG is offline   Reply With Quote
Old 05-19-2014, 01:42 PM   #2
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
Yes, it does have to come off. I had to replace my splitter last year. It's pretty easy but you do need to remove the front end. If you need some help let me know.
Deke736 is offline   Reply With Quote
Old 05-19-2014, 02:37 PM   #3
HDRDTD
Same here. I had to have my splitter replaced and it turned out that the splitter and the lower grill are all one piece, and it required they remove the whole front to change it.
Not hard to do, just big and clumsy to handle.
Old 05-19-2014, 03:32 PM   #4
01pewterz28
#TeamBeckyD
01pewterz28's Avatar
Takes about 15 minutes to remove the bumper I suggest removing the front tires it makes it soo much easier.
#TeamBeckyD
**FIFTY HBM 2SS VERT**
Old 05-19-2014, 05:52 PM   #5
big dave
Drives: 2017 ZL1
Just curious, how much does the front splitter assembly cost? In case I destroy it or something...
'17 ZL1 10.99@129 stock. 4225# raceweight. Best 60'- 1.66 on factory tires. 10.48@132 E50, intake and tune. 4270 lbs
https://youtu.be/EyHtdH9XOkY
https://youtu.be/Lcu41obbTf8
'13 ZL1 BRM A6. 11.591 @ 119.2 factory stock with a 1.68 60'! Best stock mph 121.8. 11.29 @ 123 RotoFab, drag radials and skinnies. 4360# raceweight.
http://youtu.be/yggIA3C_kkA 2014... back to stock
http://youtu.be/spQLaTWbThs 2013... stock & RotoFab
big dave is offline   Reply With Quote
Old 05-19-2014, 05:53 PM   #6
SSTG
Less than $100.
Thanks guys for the info!
