Old 05-20-2014, 12:14 AM   #1
Skijunki07
Drives: 2011 Camaro SLP ZL454 SS
Longer Iceolator bolts
If I want to use longer bolts because I am using 2 gaskets, what are the bolt specifications. The best that I can figure, they would be M8-1.25x140mm. Is this correct? Thanks, Jeff
Skijunki07 is offline   Reply With Quote
Old 05-20-2014, 07:54 PM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
You are correct sir!
https://www.boltdepot.com/Product-De...x?product=6238
I'd suggest a set of flat washers to match.
Old 05-27-2014, 12:02 PM   #3
Botoasy
Botoasy's Avatar
Drives: 2015 RRM 1LE
What did you use for the gasket? did you use the factory plastic one again?
2015 Camaro 1LE: CAI, LT Headerrs, Cam
2010 Camaro LS: BBK Longtube Headers with Hi Flow Cats, BBK CAI, SLP Loudmouth 1 exhaust, Magnaflow X-pipe and Resonators, Ported TB, Mace Ported IM and Spacer,Trifecta Tune, Elite Catch Can, Hotchkis front and rear sway bars. SOLD!!!
My Build Thread: http://www.camaro5.com/forums/showthread.php?t=272765
Botoasy is offline   Reply With Quote
Old 05-27-2014, 04:48 PM   #4
11 camaro
Drives: camaro rs
would lowes or home depot carry something like that?
11 camaro is offline   Reply With Quote
Old 05-27-2014, 05:18 PM   #5
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
Not that I can see by searching their sites. The longest at Lowe's is 110mm, and I'm not sure if that is long enough for the bolt position where you've had trouble with thread tear-out.
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 05-27-2014, 05:36 PM   #6
11 camaro
Drives: camaro rs
i dont know what else or where else to look any ideas?
Old 05-27-2014, 06:35 PM   #7
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Stuff like that is pretty tough to source locally... You could try a fastener place, like Fastenal if you have one locally. Doubt any place will have them in stock, you will more than likely have to order them online, or order them through your local fastener store.
Jason@JacFab is offline   Reply With Quote
Old 05-27-2014, 06:50 PM   #8
pgustavson
pgustavson's Avatar
The boltdepot.com link above looks promising...
Old 05-27-2014, 07:00 PM   #9
11 camaro
Drives: camaro rs
the thing is i dont even know what to ask for this is the first time i did this and never really had to look for a bolt
Old 05-27-2014, 08:07 PM   #10
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
all else fails, buy some RTV silicone gasket maker, and use the stock bolts. I've done it on 3 LLT's so far.
Old 05-27-2014, 08:25 PM   #11
pgustavson
pgustavson's Avatar
Measure the length of the bolt (in mm) you're looking to replace. Use the diagram shown on the boltdepot.com link above to guide you. Bolt length is the distance from the bottom of the head to the end. Add 10mm to that measurement. You need an 8mm diameter, 1.25 mm pitch, ### mm long bolt; where ### is the length calculated above. Sometimes written: M8 x 1.25 x ###.
The problem is that he's going to need a longer bolt in the rear position because the upper threads tore out. (From another thread in the LFX section).
Old 05-27-2014, 08:30 PM   #12
PoorMansCamaro
Drives: Really Slow
oh, didn't know that.
wasn't there a vendor here, that sold the iceolator and you could get the longer bolts through them? I thought I remember reading that somewhere. i'll do a little digging and see if I can find it.
Old 05-27-2014, 08:39 PM   #13
PoorMansCamaro
Drives: Really Slow
couldn't find it, but this thread might be helpful
http://www.camaro5.com/forums/showth...ighlight=bolts
it links to that bolt website, but has the option for other lengths.
Old 05-27-2014, 08:42 PM   #14
Ohten
Ohten's Avatar
Drives: Granite Crystal Challenger SRT
Check Fastenal they have metric flange bolts in various lengths.
Ohten is offline   Reply With Quote
