Old 05-20-2014, 10:25 AM   #1
Vespula2012
Vespula2012's Avatar
Drives: 2012 Camaro RS/SS LS3
HOW much for clear plastic?!?
Okay, so on the body (rocker panel) at the trailing edge of our doors is a small piece of clear plastic that protects this edge. (There's also a piece down underneath the rocker both behind the front wheel and in front of the rear wheel).
The one at the door edge had lifted a little on mine and had collected a good bit of dirt, and being yellow, it was fairly noticeable. So no problem, I just went ahead and removed it.
Now months later I'm realizing what GM Engineers already knew... that without it, this hard edge takes a beating from little rocks, etc. that the front wheel picks up.
Okay, no problem, I'll just replace them. Called my local dealer and I'm told they cost $55 EACH SIDE! It's literally just a tiny clear plastic sticker! Does anyone know the part number for this so I can confirm they're quoting me the right thing? (or has anyone else run into this issue)?
The Super-Devil is at least 6 inches taller, has a flying motorcycle and a jar of marmalade that we believe forces you to commit adultery.
Vespula2012 is offline   Reply With Quote
Old 05-20-2014, 06:28 PM   #2
Bulldog3071
Drives: 2010 Camaro 2SS/RS LS3
If you know the part number go to GM Parts Direct should be much cheaper
Bulldog3071 is offline   Reply With Quote
Old 05-20-2014, 06:48 PM   #3
bluBlud
bluBlud's Avatar
Drives: 2013 2SS/RS/1LE
Get a small roll of xpel ultimate film or 3m from Amazon for cheap, trim to size and install yourself. You could try the spray-on paint protection film too but I haven't read good things about that stuff.
bluBlud is offline   Reply With Quote
clear plastic, guard, rocker, shield
