![]() Drives: 2010 1ssrs Join Date: Apr 2009
What bolts to tighten up?
After working in Houston for 5 months and driving through it's terrible roads my suspension has started to creek. I have 1in bmr drop springs and they were installed 2 years ago. I did not use locate, but I did use a torque wrench. Anyways, could anyone tell me which bolts i can loctite? If i loosen some bolts and loctite them will i have to get a new alignment? Are there bolts i should not loctite because they are the bolts needed to align the car?
Thanks!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Race Car Join Date: Sep 2009
I would think if you have suspension bolts coming loose, you would have more serious problems than just "creaking". You might try just giving your suspension joints a good shot with a grease gun wherever possible.
#3 | |
Drives: Camaro Justice Join Date: Jun 2007
yes the rest is stock
Stock rubber bushings rarely squeak. How many miles on your beast?
#6 |
ITCRNRS
Drives: 2018 ZL1 1LE Join Date: Jun 2012
FE3 rear sway bar link bracket broken on one of your rear control arms? Just a thought
2018 ZL1 1LE Ordered 6/29/17 Built 11/6/17 Delivered 12/7/17, Summit White, PDR, NAV, https://www.youtube.com/c/tylerpotter
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's SOLD: 2012 Black 2LT/RS, Fully 1LE swapped, Brembo swap |
#7 |
It has 14,000 miles and it is about to turn 5 years old
#8 |
nope nothing has broken
#9 | |
You may have a bad strut. 1. Is there an oily residue on either of your rear struts? 2. Can you reproduce the noise by jouncing your car? |
