Old 05-20-2014, 08:45 PM   #1
2k132LS
Drives: 2013 2LS
will bigger rims affect 1/4 mile times
I have a 2ls and like to take it to the track sometimes and have some fun... I am thinking about going from 18'' rims to 22'' would this affect my 1/4 mile time ???
2k132LS is offline   Reply With Quote
Old 05-20-2014, 08:59 PM   #2
lscamaro
lscamaro's Avatar
Drives: 2011 CGM Camaro LS A6
Yes. Very much so. Especially if they're heavier.
Old 05-20-2014, 09:05 PM   #3
2k132LS
Drives: 2013 2LS
yes they are about 40lbs heavier
Old 05-20-2014, 09:10 PM   #4
lscamaro
lscamaro's Avatar
Yes, they'll slow you down quite a bit
Old 05-20-2014, 09:14 PM   #5
2k132LS
Drives: 2013 2LS
I guess I will just stick with the 22'' for looks
Old 05-20-2014, 10:23 PM   #6
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Yeah, you'll want the 18s for drag strips and such.
DSX_Camaro is offline   Reply With Quote
Old 05-20-2014, 11:47 PM   #7
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
What size are the tires? If they are taller than a 28.6" diameter, it will also be hurting you in the gear department. For example, a 285/35/22 is 29.9" tall...
28.6/29.9=0.9565x2.92 = (your new effective gear ratio of) 2.793:1
It would hurt you in a lot if ways. Worse braking, worse acceleration, probably handle worse, worse city Mpg...
I've never understood the whole big wheel thing myself, but different strokes for different folks. 18" is my limit.
Jason@JacFab is offline   Reply With Quote
Old 05-21-2014, 12:28 AM   #8
6bangerBOOM
6bangerBOOM's Avatar
Drives: 2016 1SS SW
I understand the importance of making the car look the way you want, but would 20's be too small for your liking? I feel that's the best balance of size to performance for many people. You still have some room for tire height/ride comfort with 20's as well, and you can also have the low profile tire look (albeit not as low profile as tires for 22's are). Either way make sure to post pics of your new wheels!
6bangerBOOM is offline   Reply With Quote
Old 05-21-2014, 08:18 AM   #9
lscamaro
lscamaro's Avatar
I don't like big wheels either but I think the Camaro needs a 19" or 20" to look real nice. And 20s are definitely the perfect balance of looks, tire choice, and performance in my opinion.
Old 05-21-2014, 09:51 AM   #10
LostInAustin
Drives: 2013 2LS
I also think 20's are the perfect balance
... I'm just waiting for my P zeros to die and I'm leaving the factory 21's forever and smiling on the way out ! Light weight 20's are the ticket.
Performance K&N Typhoon : Vmax Ported Throttle Body : Eibach Pro Kit : Flow Master Super 40's : MagnaFlow Resonated X-Pipe : GM Strut Tower Brace : FSP Tuned
Cosmetic Painted Bowties : Painted Tail Light Bezels : Blacked Out Side Markers : 19x10 Forgestar CF10's
LostInAustin is offline   Reply With Quote
Old 05-21-2014, 10:01 AM   #11
Chris14RS
Chris14RS's Avatar
Drives: RRM RS v6
I saw a 2011-ish body style Camaro yesterday with 22's. Granted they were really cheap looking rims and it looked like hell in my opinion. I'd stick with 20's. If you want to use the car for drag racing slap some wide and light 18's and some nice sticky rubber.
Chris14RS is offline   Reply With Quote
Old 05-21-2014, 03:27 PM   #12
Airmaster
Go Gators!
Airmaster's Avatar
Drives: Camaro Jeep Abarth 944 325i
Light weight 20s are my suggestion, any greater than that and you're losing...
'13 Camaro, '97 Wrangler, '12 500 Abarth, '85.5 944, '06 325i
Suspension Mods: BMR and JPSS Sways, BMR Poly Bushings, BMR strut tower brace, BMR control arms, BMR toe arms, stock springs and struts
Engine Mods: All bolt ons (haha)
Brake Mods: Brembo SS caliper swap front and rear
Airmaster is offline   Reply With Quote
Old 05-21-2014, 04:46 PM   #13
2k132LS
Drives: 2013 2LS
They are 265/35r22 . I went with 22" they don't look crazy big i just liked them better than the stock 18''
Old 05-21-2014, 05:01 PM   #14
2k132LS
Drives: 2013 2LS
Before and after
