Battery look in Z28
Someone wanted a look at the battery in the Z28
![]() Drives: 1968 RS/Custom & 2014 Z28 Join Date: May 2014
i haven't pulled mine out to get a base weight yet, have you?
![]() ![]() Drives: BAC Mono Join Date: Apr 2013
Cool! Thanks for posting!
I'd love to know the weight, my guess 45 lbs.
2014 Z/28, White
"I wasn't asked to make it cheap...I was asked to make it FAST!" Mark Stielow, the new Z/28. |
Drives: 2014 Z/28 #82+#192, 18ZLE 66Nova Join Date: Oct 2008
It at lest 37 lbs have one here and that is what that one weighs.
![]() ![]() ![]() ![]() ![]() ![]() Drives: SS 1LE Join Date: Nov 2012
Is that a ion battery?
#6 |
#7 |
![]() ![]() ![]() Drives: 2010 ZR1 "Satan" Join Date: Nov 2013
My guess is AGM technology. It's a lead/cadium battery chemistry that uses fiberglass separators. Lighter and longer life. The CTS-V has a similar sized unit in the trunk.
2002 Z06 "Blue Meanie" 11.36 ET
2003 Z06 in progress 2009 CTS-V "Spooky" 12.36 ET, bone stock at 1600 mi. Rainy day in Sacramento. Sadness. 2010 ZR1 "Satan" no times yet. 2013 Volt SCCA Solo2 #771 HS3. And a bunch of Duramaxes. |
#8 |
Dumb ass guess:
Relocate to under passenger seat. Remove long/heavy positive cable, and steel bracket. Use LiFePO4 chemistry with a BMS to avoid low voltage discharge. Unlike lead technologies, once you take a Li battery down to under 1.5v per cell, it often will not recover. It becomes trash. Total weight savings classify under Corner weight, and would be perhaps 20lb total, mostly the cable savings.
#9 |
Do you all know the part number for the z28'battery?
#10 | |
![]() Drives: Pontiac G8 GXP Join Date: Feb 2011
I'll post it here as well since I guess you didn't check back with your other post about it
![]() Quote:
1998 Pontiac Grand Prix - 11.24 @ 121
2009.5 G8 GT (Liquid Red) GXP fascia conversion, GXP diffuser 2009 GXP M6 (MSM) #405 586rwhp/495tq TVS2300, CTS-V Fuel System, Cam 222/230 116 lsa, Monster Lever 4 Clutch, American Racing 1 7/8 headers, rear Brembo's w/working Parking brake 11.91 @ 119 |
#11 |
Sorry, thanks
#12 |
no problem I forget all the time to check back on posts that I've made.-Greg
#13 |
Runs with scissors...
Drives: '14 Z/28s SIM/SW Join Date: Jan 2013
Tempting. Expensive, but oh so tempting. New category: battery porn...
![]() SEE DETAILS HERE 12V/40Ah Lithium Ion Battery with BMS - L4840 -- $1,683.16 PRODUCT DESCRIPTION The L4840 is the perfect choice for your high-end German or exotic car. The Group 48 size is a drop-in replacement for many vehicles taking 48, 49, 94R, and others from the factory. Often, it is even possible to use the factory mounting provisions. This unit offers greater reserve capacity than any of our other 12V products, in order to meet the demands of today’s sophisticated electronic loads. Cranking performance is also improved—this battery will crank over large V8s, V10s, V12s, and even diesel engines! In short, the is the ideal replacement for your factory battery, allowing you to take up to 50 pounds off your car with NO discernible difference in performance. The same cell pack is also available as the L3400 for applications where a Group 34 size is better-suited. All L series batteries feature a full Battery Management System to monitor the cell pack and ensure maximum cycle life. This includes low-voltage, high-voltage, over-current, short-circuit, and thermal protection built directly inside the battery. In the event of an issue with the cell pack, the BMS will turn off power to the terminals, isolating the cell pack and preventing failure. All L series batteries come with a 2-year, full-replacement warranty against any defect in materials or craftsmanship. ADDITIONAL INFORMATION Weight: 14 lbs Dimensions: 10.875 x 6.75 x 7.5 in Volts: 12.8 Weight: 14 CA (Pb Eq): 1000 Watt-Hours: 512 Reserve Capacity: 92 Charge Volts (max/alternator): 14.6 Charge Amps (normal/max): 184 Features: 92 minutes of reserve capacity, Full battery management system, 1000 PHCA, BCI Group 48 to replace many 48, 49, 94R, and other sizes, Our strongest 12V cranking battery, Automotive-grade LiFePO4 chemistry, Compatible with alternators (14.4V, 160A max)
#14 |
For some reason I remember a 45-pound weight on the OEM battery. God knows where, but that stuck in my head...
