Old 05-23-2014, 08:55 AM   #1
BA RS
Big B
BA RS's Avatar
Drives: 2016 2SS Summit White
Need help
OK guys I need some help with trying to figure out what's wrong with my camaro. Ok so the other day I notice that I had some liquid leaking from the bottom of the car. So I pulled in to the garage to inspect it and turns out I had a leak in the upper radiator hose. So I took it off and went to the dealership and got a new one. I replaced it and started it up. Well it almost didn't start and at first it sounded horrible. It sounded like my car was congested.Then after a few minutes it seemed to fix itself. However the stabilitrak warning came on . So I took it out for a drive and I notice that when I shift ( its M6) the RPMs seem to get stuck and it seems to take it a few seconds to lower the RPMS. It almost sounds like the transmission but I don't know. What do you guys think?
2016 2SS,NPP exhauset, A8, Black and White interior, black rims, black center stripe.
BA RS is offline   Reply With Quote
Old 05-23-2014, 10:38 AM   #2
J-vette
Drives: '14 1le
Did you disconnect something while fixing the hose & forgot to plug it back in?
Go back & check all the connections. Also make sure your fan is coming on. Give more details if possible. I assume you are out if warranty since you didn't take it to the dealer.
J-vette is offline   Reply With Quote
Old 05-23-2014, 10:48 AM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Lots of details missing in the account of replacing the hose and refilling the radiator.
Rock-It Man is offline   Reply With Quote
Old 05-23-2014, 02:02 PM   #4
BA RS
Big B
BA RS's Avatar
I took off my cold air intake tube so that I could get to the Upper radiator hose. I had to unhook the MAF connection so that I could take the tube off and then took off the hose and replaced it with the factory one I got from the dealer. I didn't take it to the dealer because it wasn't something that was that difficult to replace. Connected everything back including the MAF connection.
Old 05-23-2014, 02:05 PM   #5
BA RS
Big B
BA RS's Avatar
also I did check and the fan is coming on. I called a dealership and described the issue and the guy seemed to thing it was something to do with the throttle body after I reconnected my cold air intake tube . Not sure I agree with that but will check it out today after work.
Old 05-23-2014, 02:20 PM   #6
TommyTheCat
SHKE BKE
TommyTheCat's Avatar
Drives: 2013 Camaro
Is this a V8 or V6?
Either way they both have electronically controlled throttles and if you moved the plate at all then sometimes they need to be calibrated with a scanner. I've cleaned mine before though and did not have a problem... But some cars cannot be moved manually without requiring some sort of calibration/reprogramming of the throttle.
This is only if you moved it of course
TommyTheCat is offline   Reply With Quote
Old 05-23-2014, 03:35 PM   #7
BA RS
Big B
BA RS's Avatar
v6, and what plate are you referring to?
