Old 05-30-2014, 02:03 PM   #1
CaliDave
CaliDave's Avatar
Drives: 2014 2LT/RS Convertible
Send a message via Yahoo to CaliDave
2 ? what would you recommend for a good shine and how do you put the windscreen down?
I know this could look better. Thanks for the help
CaliDave is offline   Reply With Quote
Old 05-30-2014, 02:04 PM   #2
CaliDave
CaliDave's Avatar
Oh pictures will help thanks again
Old 05-30-2014, 02:21 PM   #3
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Adams and Zaino products seem to be popular choices as far as "systems" but many others have used a combination of other products together. Depends if you want showcar shine or something durable and don't have to go snake-sh*t when you see a dust particle land on the fender.
I've used Zaino for years and I'm happy with the shine and durability. But recently I have bought some Adams to try as well.
Regardless of the products you use, it's just like a good paint job- make corrections to the base as necessary. That's the key to a good shine regardless of the product to protect it.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 05-30-2014, 02:31 PM   #4
CaliDave
CaliDave's Avatar
More protection then shin. I don't want the Sun to beat it up later
Old 05-30-2014, 02:52 PM   #5
el ess A
Older Than Dirt
el ess A's Avatar
As far as protection goes, our 2002 Z28 we've had since new still shines well with periodic Zaino treatments since day 2 of ownership from the dealer. And it lived 99% of its life out in the driveway and hot sun of the south. So I'm a firm believer of Zaino helping preserve a "yard" car paint job. It's all the car has ever had, and the paint still shines extremely well. And it's metallic pewter.
Oh, and you had a question about the windscreen too. I'm assuming you want to leave the screen installed but lay down the top of the screen. Just grab the bar and give it a firm push back and the top should lay down. (it has a detent system so you should hear an audible click)
Old 05-30-2014, 05:30 PM   #6
CaliDave
CaliDave's Avatar
Thanks I didn't want to break it.
I'm going to get some of that stuff thanks again.
Old 05-30-2014, 07:00 PM   #7
007s 'Vert
Formerly Lil'BlueCoupe
007s 'Vert's Avatar
Drives: '13 2LT/RS Vert, Summit White
I see your are from Aiken, I worked at a dialysis clinic there up to last year, nice town, lots of good people there. Things are a lot different here in Vegas
007s 'Vert is offline   Reply With Quote
Old 07-01-2014, 09:14 PM   #8
scandata
scandata's Avatar
Drives: 2015 2SS/RS vert, Spring Green Edtn
For wax I use Eagle 1 or Meguiar's. I wax about every 6 weeks, so between waxes I just use Meguiar's Detailing spray for a beautiful, added shine. It doesn't last as long as wax, but takes a lot less time to apply (spray it on, wipe it dry). For the windows I use Invisible Glass.
scandata is offline   Reply With Quote
Old 07-02-2014, 02:08 AM   #9
CCMADONNA
CCMADONNA's Avatar
Drives: 2014 SW 2SS/RS
as far as waxes are concerned, quality products: Meguiar's, Zaino, Adam's -- it's dealer's choice. For tires, however, I use Adam's Super VRT dressing because it won't fly off the tires as i drive and dirty my white car.
CCMADONNA is offline   Reply With Quote
Old 07-02-2014, 09:07 AM   #10
babaron
Totally into it
babaron's Avatar
Drives: '67 427vette/'11 Pacecar/'02 BMW ci
Black Fire Wet Diamond wax is the best I've used. And it's endorsed by Camaro Dreams 007 in his comprehensive product recommendation guide, which is a good source of info for all car care products. See the sticky at top of forum.
____________________________________THERE MUST BE A SUPPORT GROUP FOR THIS ADDICTION. AM I IN THE RIGHT PLACE?
babaron is offline   Reply With Quote
Old 07-02-2014, 09:43 AM   #11
Indydriver
Drives: '14 2SS/RS Vert 6M/KTU/NPP/DTA/ARH
The windscreen is easy to manipulate even while driving. I use Zaino on the exterior but just recently got exposed to Adams for interior cleaning and leather protectant. Good stuff.
Consensus is, by definition, a lack of leadership.
Indydriver is offline   Reply With Quote
Old 07-30-2014, 10:54 AM   #12
SwaeOcean
SwaeOcean's Avatar
Drives: 2013 ZL1
You can, as previously stated, push the windscreen down. This has been how I put mine back when I have the top up, its night and I realize I can't see thru the back well enough. But I would caution against it. If you can, use the red tab behind the drivers seat, its located where the vertical and horizontal pieces come together. I say this because my windscreen is starting to wear. It is sliding apart (the tubes from the corners) as well as the plastic foot that 'clicks' in as the hinge bending itself outwards.
Looking for higher quality windscreen and tonneau. :/
SwaeOcean is offline   Reply With Quote
Old 07-30-2014, 05:38 PM   #13
Indydriver
I like your color combo.
+1 Zaino, Adams, GM Windscreen!
