Old 05-30-2014, 03:01 PM   #1
Awdition
Camaro out>CTS-V coupe in
Awdition's Avatar
Drives: CTS-V
SOLD:RANGE V8 With OBDII Right-Angle Extension $140
The best mod you can do with an L99 Auto - disable the Active Fuel Management!
This is a must if you don't enjoy half your cylinders deactivating randomly and don't want to tune the ECU. It is stealthy and does not void the power-train warranty in any way
This is a Range V8 (Serial 001226) with an OBDII extension so that you can tuck the Range in the door column in the foot well (unless you want a blue foot well light - in which case plug the Range in direct )
I ran it for 18 months with no problems - but disconnect when you leave it for a couple of weeks at the airport, it will slowly drain the battery otherwise (normal behavior for one of these).
Asking Sold.
CTS-V Coupe Black Diamond Edition
Awdition is offline   Reply With Quote
Old 05-30-2014, 04:00 PM   #2
BronxxBombers213
BronxxBombers213's Avatar
Drives: 2010 Camaro 2SS RS
have the same exact setup.. love both pieces !
BronxxBombers213 is offline   Reply With Quote
Old 05-30-2014, 06:59 PM   #3
Awdition
Awdition's Avatar
Drives: CTS-V
yeah - I probably copied you to begin with! The right-angled extension makes a huge difference to the Range too since it sits more flush in the ODBII port and you're less likely to catch a leg on it.
Old 05-31-2014, 09:06 PM   #4
Awdition
Awdition's Avatar
Drives: CTS-V
Price reduced to $140 shipped.
Old 07-03-2014, 01:39 PM   #5
AuburnGrad93
AuburnGrad93's Avatar
Drives: 2018 Ford F-150 Lariat 4x4
Asking Sold.
Where did you purchase the extension at??
1999 30th Anniversary Convertible Trans Am
2001 SOM Convertible Trans AM
2012 2SS/RS Summit White Convertible
My Build Thread: http://www.camaro5.com/forums/showthread.php?t=224339
AuburnGrad93 is offline   Reply With Quote
Old 07-03-2014, 01:44 PM   #6
BronxxBombers213
haha yep! i was the first to do it i believe
congrats on the sale ! :-)
