Old 06-01-2014, 12:13 PM   #1
BFASTNOTLAST
BFASTNOTLAST's Avatar
Drives: 2012 SS LS3
Comp cam @ 5,000 miles
I figured I would pass along this info for those of you who have had the same kind of cam whine as I have had. These pictures were taken with 5,000 miles on this cam since new. The lobes are LSL and the lift is under .625
I had whine from day one and seemed to get a bit worse towards the end, the reason why I took it out... This was also ran with a single beehive spring nothing aggressive there. It's hard to make out in the pictures but as you see where the lifter was following the cam there seems to be what looks like ridges or chatter in the contact area. You can't feel the ridge with your fingernail but it's visible.
So, right or wrong I chose to just change the cam and took a chance not changing the lifters. VIOLA..No more cam whine with a different cam manufacturer. I will more then likely change the lifters when the heads come off this winter.
My set-up was run with LS30 oil from day one, so I'd like to think that's not a contributing factor in this.
Take this for what it's worth, just wanted to make you aware of what you may be up against if you have the whine like I did. Remember this was only 5,000 miles on this stick.
BFASTNOTLAST is offline   Reply With Quote
Old 06-01-2014, 07:52 PM   #2
NinoSS
Drives: 2SS/RS CGM LS3
wow, that cam would definitely have gotten worse over time. Good call getting a new cam in there...
Current - 2018 NGM 1LE (LT4 conversion coming soon)
SOLD 2010 LS3 / Vengeance stage I cam / CAI intake w/ADM race scoop / Dynatech LT's / Eaton Posi LPE-JRE 3.91's / L99 Corsa / ZL1 wheels / NT05 275/315
NinoSS is offline   Reply With Quote
Old 06-01-2014, 10:17 PM   #3
VADER SS L99
VADER SS L99's Avatar
Drives: 2013 A6 GT 5.0
Lot of this crap going around lately. Good you got it changed out before you had more serious problems down the road. LSL lobes are pretty mild as well. Oil quality pretty much gets ruled out as well with LS30. Did you send it back to Comp?
Old 06-01-2014, 10:44 PM   #4
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
That's impossible. A good quality oil is ALL you need. I've seen it posted several times now.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-01-2014, 11:31 PM   #5
VADER SS L99
I think you misinterpreted my post. I am saying oil quality was most likely not a factor in the wear.
Old 06-01-2014, 11:46 PM   #6
BigRed
BigRed's Avatar
Drives: SS RS SIM
Vader, I think he was being sarcastic. LOL
BigRed is offline   Reply With Quote
Old 06-02-2014, 12:04 AM   #7
VADER SS L99
Ohh right, I'm a little slow tonight
Old 06-02-2014, 12:45 AM   #8
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
What, a failure with LS30, please don't tell ChristianChevelle!
Rhino79 is offline   Reply With Quote
Old 06-02-2014, 01:58 AM   #9
axis
Search Ninja
axis's Avatar
Yep.
Halltech CF 102 fed
Old 06-02-2014, 02:33 AM   #10
rberns
rberns's Avatar
Drives: 2011 Camaro 2SS/RS
I've got him added to an ignore list. It's safer I do that than say something that will get me suspended.
2011 Camaro 2SS/RS, Circle D 3200, ADM Transmission Cooler, BTR Valvetrain, Cam Motion .621 .595 228/244 113+4, ARH 1 7/8 full exhaust, Cold Air Inductions, Katech C5R TC, Melling HV, BTR SLR lifters, Trunion Upgrade, LS2 Dampner, LS9 head gaskets, Bo White PTB, MM can, GFX, Subs, B&M Deep transmission pan,
Holley fuel rail, Proform valve covers, relocated coil packs
rberns is offline   Reply With Quote
Old 06-02-2014, 06:49 AM   #11
1sick_eg
Drives: 14 Camaro 1LE,328i, and some Hondas
I tried not to laugh about the oil thing, but I did. I'm sorry.
First pic I thought "Eh, looks fairly normal.". Second and third pic however, good catch. Definitely on it's way to failure. Like I said before, it seems that cam cores themselves are the problem. We've had this problem with parts at work. Too much outsourcing and not enough QC anymore.
1sick_eg is offline   Reply With Quote
Old 06-02-2014, 07:35 AM   #12
WiredAVS
WiredAVS's Avatar
Drives: '21 TRx '22 ZLe
What I'm curious to see is other cams for reference.
Anyone have pictures of a "whining cam" that has 10-20k miles on it with no known running issues besides whining? Maybe removed due to whining or upgrade.
Also any pics of a "non" whining cam with the same criteria. No known running issues and 10-20k miles.
If so please post with brand/miles/whine/no whine.
ePhone
2014 Camaro 2SS/1LE AGM/768rwhp
Recaro's, Custom Autometer Gauges, Hotchkis 1" Lowering Coils, CAi Intake, Elite Catch Can's, 1 7/8" StainlessWorks LT's w/Hi Flo Cat's mated to factory NPP Exhaust, 160* Thermo, NightFury Cam, 2.9l Whipple on Meth @ 11lbs, JoeGibbs LS30 in the CrankCase, Built by Nick, Steven, and Tuned By Shawn at Lethal Racing....
WiredAVS is offline   Reply With Quote
Old 06-02-2014, 08:24 AM   #13
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 06-02-2014, 11:38 AM   #14
BFASTNOTLAST
Drives: 2012 SS LS3
Been busy so far today, I will try to get it out to Comp tomorrow. I'll keep you posted to what they have to say about it.
