![]() Drives: 2012 2SS/RS Join Date: Apr 2014
Need Help With 2012 Tire Pressure Sensors
I am trying to recalibrate my tire pressure sensors but the links I found on here don't work for the 2012. I get the car to beep twice to start but after I let out air nothing happens. Does this mean I just have to have the dealership do it since i don't have the tool that is needed?
Flowmaster American Thunder Exhaust
![]() ![]() Drives: 2010 camaro ss Join Date: May 2009
any large shop will have the tool but it may cost a few dollars
so there is no way to do it ourselves?
Plays with Hot Wheels
Drives: '17 Jet Black ZL1 Join Date: Apr 2010
Check the owners manual.
Previous Cars: '78 Z28, '92 Z28, '95 Z28, '85 Corvette, '01 SS, '96 Z28, '04 Z06 Corvette, '10 SS, '13 SS Hot Wheels
Current Cars: '17 ZL1(daily driver), '04 Trailblazer (rain & snow), '66 Corvette (restoring) |
![]() Drives: 2011 SS (Sparrow Spearer???) Join Date: Aug 2013
take it to your dealership. they might do it for free and right on the spot.
Black magic woman, don't turn your back on me baby!
#6 |
You can purchase the tire pressure gauges in any auto parts store, or a department store like Walmart or Target.
#7 |
![]() ![]() Drives: 2014 1LS M6 Supercharged Join Date: Feb 2011
Make sure your HandBrake is on. Start the test, Once the car beeps twice , add or remove air pressure to the front left tire( I usually count to 10) now wait for the sensor to update, this might take up to a minute. When it beeps, repeat step on the front right tire, then repeat for the right rear, then left rear, when test is completed, you'll get a double beep again.
#8 | |
Mechanical Engineer
Drives: 2012 IBM Camaro 2SS/RS A6 Join Date: Oct 2008
Current Vehicle: 2012 Chevrolet Camaro SS
Past Vehicle: 2001 Honda Prelude SS ![]() LEFT HAND DRIVE |
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro 1LT/RS Join Date: Sep 2013
Go into any discount tire or America's tire and they will do it for free.
Detailing is an involuntary obsession.
#10 |
I can do it on my dad's 2012.
Press the set/clr button on the DIC until it says you are about to clear and learn the sensors, are you sure you want to do this. Press yes. It will honk to indicate it is learning, and the left front turn signal will be lit up solid. The trick is to let the air out of the drivers left tire for about 10 seconds. Wait about 30 seconds and it should beep and go to the next tire. That seems to work for me. It is slower than the 2010 to get it to learn but it works with his all seasons and the original 2012. Both have OEM sensors.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
#11 |
376 cubic inches of fun
It's so much easier with the reset tool.
