Old 06-05-2014, 08:52 PM   #1
camaroguy89
Drives: 2011 2SS/RS
dose this seem faster than stock?
mine 2011 2SS 60-130mph
camaroguy89 is offline   Reply With Quote
Old 06-05-2014, 08:56 PM   #2
5thgen(D4yWalker)
5thgen(D4yWalker)'s Avatar
Drives: 20125thgen
Not really sure..but nice1
5thgen(D4yWalker) is offline   Reply With Quote
Old 06-05-2014, 09:05 PM   #3
camaroguy89
Drives: 2011 2SS/RS
i wasnt sure but i just look at this video
he dose 60-128 in about 19s
i do 60-130 in about 13.5s
Old 06-05-2014, 09:11 PM   #4
ABMLS3
ABMLS3's Avatar
Drives: 2010 Aqua Blue Camaro 2SS/RS
Seems faster then stock
Since it's the same subject, my TT camaro did 30-140 in 13 seconds 60-130 in 7 seconds
Power Source Performance Turbo Kit
416 C.I ,TH400
Instagram: TomTraube
COTW ABMLS3 Build Thread
ABMLS3 is offline   Reply With Quote
Old 06-05-2014, 09:18 PM   #5
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Run a couple 1/4 mile times and note the mph. That should tell you if you're a little faster or not.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-05-2014, 10:02 PM   #6
camaroguy89
Drives: 2011 2SS/RS
what does a stock SS do in a 1/4? ive been told 14.1 and 13.6
Old 06-05-2014, 10:18 PM   #7
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Stock SS typically runs anywhere from 12.9 to 13.5 in the 1/4 at between 105 to 110mph. It would not take too much more to hit 130. A bone Stock one can day 0-120 in just over 15 FYI.
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 06-05-2014, 10:23 PM   #8
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
depends on the track and elevation...and driver.
Old 06-05-2014, 10:40 PM   #9
87GNX
87GNX's Avatar
Drives: Alot
I went 13 flat in good weather...takes some mods to get into the 12's for the most part.
87GNX is offline   Reply With Quote
Old 06-05-2014, 10:41 PM   #10
camaroguy89
Drives: 2011 2SS/RS
so do you think i could hit mid to high 12s?
Old 06-05-2014, 10:41 PM   #11
jrhagen
Banned
Drives: Camaro
I believe you meant quicker not faster.
jrhagen is offline   Reply With Quote
Old 06-05-2014, 10:45 PM   #12
PoorMansCamaro
Drives: Really Slow
depends on your mods and the track elevation.
Old 06-05-2014, 10:45 PM   #13
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
No. 12's is not the norm for a stock car and that video doesn't suggest you could do it.
Old 06-05-2014, 11:08 PM   #14
camaroguy89
Drives: 2011 2SS/RS
mine isn't stock. im not sure what all has been done to it but i was told it was putting out close to 500hp at the crank but i wont know for sure till i get it on a dyno.
