![]() Drives: 2010 Camaro 2LT RS Join Date: Sep 2012
Maryland Help Needed!
Hello there, does anyone know any place in maryland (closer to baltimore possible) that can fit my car with a turbo kit or supercharger? if so around how much it's going to set me down? and where it is (name and number if possible) or to even get it tune up.....
Or even where could I get it tune as it sits right now: 2010 2LT RS - 35,000 miles - 6 Speed Manual Right now the car has the following: - JB Heathers - RX Can - Injen Cold Air Intake - Cat Back System 3" - I'm thinking of installing a throttle body spacer (will these make any difference) OTHERS: - Short Shifter - Eibach Pro Series Lowering Springs - Tints 35% in ALL windows - LED's (Dome Light, Trunk, License Plate Lights, Under Door Strip - Plasti Dip Black Wheels and RS emblem on back. - Painted Calipers - DRL's conversion, on all the time - Smoke Tail Lights, Side Markers, Revers Lights - Vinyl Black Bow Ties front and back, Shark Gills NEXT PROJECTS: - Footwell Lighting front and back (LED Strip) - FIND a place to get it tune (the reason for this post) or get it fitted with a turbo or super charger system. I'm in Manchester, Maryland. If anyone knows a place around please let me know. THANKS in advanced and appreciate the forum...Great job... |
Drives: 96SS Join Date: May 2009
We can do anything you need. Give us a call.
![]() Drives: 2010 Transformers Edition Join Date: Nov 2009
Huh? Your in New Castle, I'll have to remember that.
![]() Drives: 2010 2SS RS M6 Blk Join Date: Jul 2010
FBC Performance is right across from Camden Stadium in Baltimore. The owner, Jason is very knowledgeable and a good guy. They've turbo/supercharged a slew of different applications (primarily domestic, including a pile of 5th gen camaros as well). They will build, install, tune whatever you want. Labor rates are excellent and turn around time is very reasonable.
Give Jason a call @ 410.242.0404 (Tell him Steve sent you, he did my 418 stroker beast SS).
418 LS3, custom cam, tuned vararam, ported tb, Kooks stepped LT's, Kooks Hi-Flo cats and 2.5" street sleeper cat back, 18% UDP, crap stock rear tire size 12.03 @ 117 mph.
#6 | |
Go NY Giants & NY Rangers
Drives: 2013 ZL1 M6 Join Date: Nov 2013
#7 | |
work done
it was nice talking with you we will be happy to get you up and running right |
#8 |
Army EOD Vet
Drives: 2010 2SS/RS blk/blk/blk Join Date: Jul 2009
Fran at RPM does good work, a walk around his shop and 5 minutes talking to him and you will feel the same confidence that I have in him.
2010 2SS/RS Blk/Blk Camaro F1A Procharger
#9 |
Appreciate the info!
Thanks guy for the info....Anyone going to Frederick for the Camaro show next weekend?
#10 |
![]() Drives: 2011 cyber gray SS Join Date: Oct 2012
Fran at RPM is the man!!!!
