Old 06-10-2014, 09:27 AM   #1
zfuzz
zfuzz's Avatar
Drives: 69 Z28 / 12 ZL1
Supercharger replacement / Flutter ?
So on this supercharger replacement deal no one has mentioned the note in the TSB that manual transmission cars will experience a flutter / rattle. What the heck is up with that? Anyone with experience with this yet?
From TSB....
Note: To improve reliability of the supercharger one of the changes made was to go to a solid coupler between the geartrain and the drive pulley. A tradeoff to this improvement is that manual transmission vehicles may experience a flutter or rattle at low RPM (800-900) and high load (second or third gear). This flutter only lasts a moment and is a normal characteristic of this design.
zfuzz is offline   Reply With Quote
Old 06-10-2014, 09:42 AM   #2
HDRDTD
From TSB....
this could be in part, what the original spring coupler was designed to help alleviate as the spring would absorb some of the vibration.
now that they will be using a solid coupler, this inherent 'rattle' will not be absorbed and you may hear a bit of it under certain conditions.
Note: this is ALL speculation on my part.
Either way, note the conditions mentioned in the TSB.
Low RPM (800-900) AND high load (second or third gear)
and will be momentary.
How often would you be driving your manual ZL1 at those rpm's and high load?
just about as often as you would encounter the dreaded 'skip-shift'.
I'm not worried in the least.
Old 07-11-2014, 11:09 AM   #3
Samson2029
Drives: 328xi, ML400, ZL1 man. 2013
annoyed by this flutter or rattle, passengers new to my car ask me what is that noise. Have to tell them there is nothing wrong with the car and that it is normal. One friend told me you should have bought a german car. anyways this is not fun for a high priced car. I am sure it will contribute to the cars overall second hand value.
Samson2029 is offline   Reply With Quote
Old 07-11-2014, 12:00 PM   #4
HDRDTD
Once AGAIN, if you can hear the rattle, take it to your local dealer. the SC will be replaced under warranty.
Old 07-19-2014, 05:25 AM   #5
Samson2029
Already got the new upgraded SC. Under light acceleration in first gear there is a brief but obvious rattle. I consider this a real turn off. Now I have to be more aggressive on the throttle for it not to rattle. Do the new 2014 and 2015 manuals have this rattling with its facory installed upgraded SC?? Any mods to reduce this rattle other than getting a louder exhaust?? For this momentary rattle to be mentioned in the TSB doesn't make it right or "OK". Customers should not accept this after paying close to 60 000$ This is an engineering screw up by GM and Eaton. If I were to test drive a 2015 zl1 and have noticed this vibration or rattle related to the solid isolator, it would have been enough for me not to purchase the car. Each customer is different but right now for me this is a real turn off and this may very welll be my last purchase from from a domestic car manufacturer. Going back to the dealer in hope that there is some adjustment to make this vibration/rattle less obvious. This will be my eighth visit to the garage ever since I purchased my 2013. (Transmission grinding noise, exhaust failure, front left wheel noise, back right suspension clunking, a damaged wheel by garage lift which the dealer denied, supercharger replacement, regular maintenance, and soon the key fab).
Old 07-19-2014, 08:21 AM   #6
Schmo Z
Drives: IOM ZL1
What was diagnosed for the suspension clunking noise?
Schmo Z is offline   Reply With Quote
Old 07-19-2014, 08:23 AM   #7
jdsblueray2013
Drives: 2013 Camaro 2ssrs Blue Ray
Send a message via Yahoo to jdsblueray2013
WTF! All that money! That would annoy the hell out of me!
jdsblueray2013 is offline   Reply With Quote
Old 07-19-2014, 08:43 AM   #8
RLHMARINES
1st Civ. Div.
RLHMARINES's Avatar
Drives: Camaroless for now...RIP "Big SexZ"
I had mine replaced and I knew from GM's statement of what to expect on the noise for our manual cars. I have no problem with this because it is after all a high performance muscle car and you will have more mechanical sounds. I love the increased performance of the new blower and the enhanced sound coming thru my c.a.i. intake.
Swift....Silent....Deadly
RLHMARINES is offline   Reply With Quote
Old 07-19-2014, 09:05 AM   #9
boondocksaint
Cartoon Maus
Drives: White ZL1, Chevroyota Prizolla
The solid coupler is a mod a lot of people have done and I don't remember reading any complaints from them.
I don't ever even see the skip shift indicator, so I'm not concerned on the low RPM stuff. When I'm touching the redline in 3rd, I'm on a track with the windows down and a helmet on.
But my original springy coupler has yet to ________ ________. I can't actually type it, because as soon as I do, it will.
boondocksaint is offline   Reply With Quote
Old 07-19-2014, 11:15 AM   #10
Samson2029
The clunking noise in the rear suspension remain sun resolved. Nothing loose or broken. The suspension works perfectly. Was told to return if noise worsened. The clunking is an infrequent noise and happens only on certain types of road imperfections like going backwards out of an inclined parking or going up a hill and hitting the right type of road imperfection that is not to deep and not to small. The technician was unable to reproduce the noise on testing.
Concerning the New SC rattle my habit is to take off with minimal of RPM. So I am often in the 800 to 1000 rpm. Is my manual skills bad??
Old 07-19-2014, 03:05 PM   #11
CRTZL1
Banned
Drives: 2013 CRT ZL1
I have the new supercharger installed now for a month or so and I have noticed zero flutter or rattle ..
Mine is a manual as well..
CRTZL1 is offline   Reply With Quote
Old 07-19-2014, 09:32 PM   #12
Vroom
Drives: 2013 Camaro ZL1
Wow, deja vu. Can't seem to win with these eatons
  • 2013 Victory Red ZL1 - 210K+ miles. Mods: Who needs mods...its a freaking ZL1 - Last car: 2006 GTO
Vroom is offline   Reply With Quote
Old 07-19-2014, 09:39 PM   #13
Jakeman
Jakeman's Avatar
Drives: 2013 ZL1
Got letter too. Said they would replace or reimburse if you had to pay for a fix.
I haven't heard any rattle at this time, 8000 miles.
Past Camaros: 1970 SS 350, 1984, 2012 2SS/RS Vert; Vettes: 1993, 2004 Vert; 2008 ZO6
Jakeman is offline   Reply With Quote
Old 07-20-2014, 01:35 PM   #14
djnice
djnice's Avatar
Drives: 13 ZL1 SIM, 99 Z28 Black
Did you leave the CAI on when you took it to the dealer for the SC?
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
djnice is offline   Reply With Quote
