Old 08-08-2009, 10:19 AM   #1
bbtr5
Drives: 98 Camaro V6
Exclamation Need help
Hi, i need help
When im driving, i cannot shift to 5th gear, or reverse. i have 1st through 4th, but not 5th or reverse. Please help me.
P/S: its a 98 five speed V6 if that helps
bbtr5 is offline   Reply With Quote
Old 08-08-2009, 10:24 AM   #2
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Grinding when going into 5th under load?
With the car off can you shift the shifter into 5th position and reverse? Any binding?
Pull the boot and make sure the shifter isn't being blocked by anything near the linkage.
Zabo is offline   Reply With Quote
Old 08-08-2009, 10:38 AM   #3
bbtr5
nope, can't even get in 5th
i don't know what you mean by binding, but i can't even get the shifter to find 5th or reverse
I will try pulling the boot
Old 08-08-2009, 11:38 AM   #4
bbtr5
well, i took the boot off, and there was nothing blocking the shifter, so what else could it be?
Old 08-08-2009, 01:20 PM   #5
Zabo
Gunning for Sixth
Zabo's Avatar
Binding meant did the shifter hang up anywhere shifting into the 5th/reverse area.
If you can't shift into 5th or reverse and feel it click into place even with the car off it's probably internal. Looks like it's time to pull the tranny and pop her open. Was it gradual or just one day at a light *ding* no more 5th/Reverse?
Lower 4 gears shift fine, right?
Old 08-08-2009, 09:51 PM   #6
bbtr5
Yeah, the lower four gears work fine. Last night, i had 5th and revverse, but today, after parking, i tried reversing, and i couldn't put it into reverse. I had to put it in neutral, and push it out of the spot.
Old 08-08-2009, 10:34 PM   #7
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
and it wont go into reverse or 5th when the car is off?
sounds like a reverse lockout solenoid is on the fritz
I piss excellence
and fart awesomeness
Old 08-08-2009, 10:47 PM   #8
bbtr5
Okay, Thank you.
One more question. Is it possible to put a 6 speed tranny instead of a 5 speed?
If it is, what would need to be changed?
