Old 06-12-2014, 12:58 PM   #1
Nickey31
Nickey31's Avatar
Drives: 2012 Nickey ZL1 #001, 2014 Corvette
Replaced seats, how to trick airbag DTC
Both of my front seats were replaced with seats that do not have airbags. I now have following codes:
B0014 OD Driver seat side air bag deployment loop
B0021 OD Passenger seat side air bag deployment loop
B0079 04 Driver seat position sensor circuit open
U0170 00 Lost communication with passenger presence module
Pulling fuses or relays don't solve anything. I am looking for a way to close the loops or trick the program. Honestly, the idiot lights don't bother me whatsoever. However, somehow one or all of these DTCs causes the car to turn on the hazard lights and call Onstar Emergency at higher speeds. I disconnected the onstar cables going in and out, so the call doesn't go through, but the voice comes over the speaker system stating that it is trying and it rings, as it attempts to complete the call. Additionally, the only way to turn the flashers off is to turn the car off.
Surely someone else has replaced the seats and figured out how to bypass all of this.
Thanks
Nickey31 is offline   Reply With Quote
Old 06-12-2014, 01:09 PM   #2
SNSSTR
All About That Speed
SNSSTR's Avatar
Drives: 2010 Camaro 2SS/RS
I need to know as well
2010 SS M6 | 416 CI | H/C/I | GPI TUNED | SNSSTR
SNSSTR is offline   Reply With Quote
Old 10-26-2014, 08:24 PM   #3
2sscamaro11
Drives: 2011 ss camaro
Any updates on this?
2sscamaro11 is offline   Reply With Quote
Old 10-26-2014, 08:28 PM   #4
Chevrolade
Drives: 2010 2SS/RS
No one knows how if they do they don't give out the secret
I have already tried researched lol
Chevrolade is offline   Reply With Quote
Old 10-26-2014, 09:25 PM   #5
rydahog
rydahog's Avatar
Drives: camaro ss
one of the more knowledgeable folks here is OFER, from gen5..diy2ssrs. i would throw a shoutout to him.. jus sayin..
or this..http://www.camaro5.com/forums/showthread.php?t=277732
rydahog is offline   Reply With Quote
Old 10-27-2014, 05:20 AM   #6
Scotty D
Drives: 2014 1le 1SS CRMT
A resistor ! You have to meter out the air bag I believe !
Scotty D is offline   Reply With Quote
Old 10-27-2014, 11:30 AM   #7
Nickey31
Nickey31's Avatar
PM me for the fix.
Old 10-27-2014, 11:39 AM   #8
franknbeans
Whipped
franknbeans's Avatar
Drives: 2010 CAMARO
because the fix is a secret?
franknbeans is offline   Reply With Quote
Old 10-30-2014, 10:26 AM   #9
2sscamaro11
Anyone care to post where to put said resistor? I know I it goes in the main connector under the seat...but what two pins does it connect?
Old 04-07-2023, 05:20 PM   #10
claudiel19
Drives: Camaro SS 2014
Bump. Having these same codes now
claudiel19 is offline   Reply With Quote
Old 04-18-2023, 09:55 AM   #11
MikeSpiller
MikeSpiller's Avatar
Drives: Chevy Camaro Z28
Man, I don't recommend you doing it in the first place. But if you really wish to... Well, here it goes:
One option is to try and reset the codes by disconnecting the battery for a few minutes. This may clear the codes temporarily, but they may reappear once the system detects the missing airbags again.
Another option is to use a diagnostic tool to bypass the airbag system (OBD-II Scanner? Airbag Reset Tool, Multimeter). However, this can be tricky and may not be legal in some areas.
So, the point is, you better not to do it, man. It's technically possible, but for me safety comes first.
MikeSpiller is offline   Reply With Quote
Old 05-20-2023, 06:55 PM   #12
Blue 13
3P171 USAF Combat Arms
Blue 13's Avatar
Drives: 2013 SS/RS
I have racing seats and 5 point harnesses so it’s safer than seat airbags, but to answer the question here’s what was posted on here a few months ago:
Blue 13 is offline   Reply With Quote
Old 06-04-2023, 08:35 PM   #13
Howell55
Drives: CHEVY 2010 SS, CHEVY 2019 SS 1LE
How did you bolt down the seat. I just installed a set this am but there is no way to finish tightening the 50 torx.
Howell55 is offline   Reply With Quote
airbag, dtc, replaced front seats
