Old 06-12-2014, 03:10 PM   #1
CAMOETO
Drives: 2013 2SS 6M
Exhaust opinions?
Ok, I was hoping it wouldn't have to come to this but after four tries and two months of tinkering I still haven't found a combination that I'm currently 100% satisfied with. Here is a brief history of my configuration:
1. Picked up the car with straight pipes welded in instead of mufflers - was too loud for my taste and boomy sounding throughout the rev range.
2. Put on a set of stockers - too quiet! Actually this was even quieter than the stock exhaust on my G8 GXP was.
3. Installed a set of SW long tube headers with high flow cats. Still too quiet but now sounded better at higher RPMs.
4. Installed a set of GMPP touring mufflers to replace the stockers. Much better now, especially at > 3500 RPM, great quality sound at those RPMs. I still don't quite like how it sounds at < 3500 RPM though. Although better than straight pipes the sound is kind of nondescript and a little boomy to my ears.
Here is what I'm considering as my next possible steps:
- NPP. This may solve the low-rpm issue but the mufflers look suspiciously a lot like my GMPP touring mufflers. Will this really be an improvement?
--OR--
- Corsa. I ran a similar combo (Long Tubes + Corsa) on my first G8 and loved the sound. Much more interesting and distinct than what I get on the Camaro. The mufflers that come with Corsa's Camaro system look different though, smaller in particular. I'm not really looking for more volume.
I would really appreciate any opinions on the two options above or any other suggestions.
Current: 2013 Camaro 2SS/Manual, 2014 Mazda3i/Manual, 2014 Mazda3i/Auto, '08 Tuono 1000R
Last 3: 2009 Pontiac G8 GXP/Manual, 2007 BMW 335i/Manual, 2008 G8 GT/Auto
CAMOETO is offline   Reply With Quote
Old 06-12-2014, 10:06 PM   #2
CAMOETO
Drives: 2013 2SS 6M
Anyone? Corsa vs. NPP?
Old 06-12-2014, 10:34 PM   #3
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
I think it's drone that's bothering you. Very common once the stock muffler is removed. You would need a muffler with a drone solution like Solo. I think Corsa has no drone as well, but not 100% sure.
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-16-2014, 01:38 PM   #4
CAMOETO
Drives: 2013 2SS 6M
There is a small bit of drone on my current setup at about 1600-1700 RPM, but that's easily avoidable and doesn't bother me at all. It's the quality of sound at low RPMs that I don't like. I'm looking for something a bit brighter or more exotic sound perhaps. I seem to remember that Corsa was that way on my G8 so maybe I will just go with that.
I've been in cars running various Solo systems and wasn't impressed at all. I know they get hyped up here and are very active on the boards in general but as for actual sound quality, I didn't like it.
Old 06-16-2014, 02:18 PM   #5
FaytalsCamaro
Distributor of Liquor
FaytalsCamaro's Avatar
Drives: My Wife Crazy
Magnaflow Resonated X pipe.
Wham, Bam, Thank you ma'am
FaytalsCamaro is offline   Reply With Quote
Old 06-16-2014, 03:03 PM   #6
Tim417
Drives: 2013 Camaro 2SS
When I got my Camaro I got a great deel on a Magnaflow street car back system which overall I am happy with. If I could do it all over again, I would keep the stock system and get the Noweeds diverters. That way I can have it as quiet as I want for freeway driving with family, and as loud as I want whenever. Remember that cat back systems only affect sound and is not a power adder. You will need headers or hi flow cats for that.
Tim417 is offline   Reply With Quote
Old 06-17-2014, 09:58 AM   #7
CAMOETO
Drives: 2013 2SS 6M
Got long tubes and high flow cats already, and got the car dyno tuned at Livernois, runs like a beast
It's just the sound part I'm trying to nail down. I think the X-Pipe suggestion from above could work, but in that Case the Corsa system would be a cleaner install since it already comes with an X-Pipe.
Old 06-17-2014, 10:13 AM   #8
caverman
caverman's Avatar
Drives: '69 SS Convertible
Personally I like the 3" Magnaflow comp cat-back with LT headers. I haven't priced them in a long time but they used to be a lot cheaper than Corsa.
I think a real popular setup is LT headers with either 3" Magnaflow, Corsa, or Borla S. I will say that I listened to my car next to a Borla S setup and they sounded almost exactly the same. Again, Borla is usually way more expensive than Maganaflow.
Everyone has their own opinion on what sounds good and what has or doesn't have any or too much drone. Your best bet before you just start tossing money around is to see if you can hook up with a group of 5th Gens in your area and listen to different setups in person.
Call Tyler or Jordan over at JDPMotorsports.com. They sell a bunch of performance and exhaust parts for our cars. They also race a 5th Gen and have a bunch of hands on experience with different Mfg of parts. See what they recommend after you tell them what you're looking for.
Build Journal
Old 06-17-2014, 01:52 PM   #9
CAMOETO
Drives: 2013 2SS 6M
I've heard the Borla S system before - too loud with headers for my taste.
Old 06-17-2014, 02:53 PM   #10
caverman
caverman's Avatar
If that one is too loud then you'll probably need to stick to something like the Borla Touring. You're not going to have that many options for a system that is much quieter than a Borla S or 3" Magnaflow.
Borla Touring, maybe the NPP system or you'll probably need to add the resonated X-pipe to your LTs and OEM mufflers.
From my understanding the Corsa is similar to the Borla S and 3" Magnaflow. Fairly mild until you get on it some and then it will really wake up.
Build Journal
Old 06-17-2014, 04:29 PM   #11
CAMOETO
Drives: 2013 2SS 6M
I'm not currently running stock mufflers, my current setup is SW long tubes with high flow cats, stock mid-section running into GMPP touring mufflers which many say are similar to Borla Touring. They also look similar to NPP mufflers.
I think I will try to find someone local with either long tubes with NPP or long tubes with Corsa to listen to and go from there. From what I remember of running Corsa with long tubes on the G8 is it was about the same volume wise as my current setup and louder at WOT. I think it sounded more interesting overall.
Old 06-17-2014, 08:42 PM   #12
Constj1
"Constantine"
Constj1's Avatar
Drives: 2014 Camaro SS Summer Edition
I love the smooth deep sound of my Borla S type mufflers.
Constj1 is offline   Reply With Quote
Old 06-17-2014, 08:45 PM   #13
Constj1
"Constantine"
Constj1's Avatar
The Borla S is the mid level sound. The attack is the most aggressive.
