Old 06-14-2014, 09:23 PM   #1
Droptopscott
Droptopscott's Avatar
Drives: 2014 1lt rs convertible
Convertibles and snow
What do you guys do in the winter if you don't have a garage and it's snowing. Will snow piled up on the top hurt it?
Droptopscott is offline   Reply With Quote
Old 06-15-2014, 12:29 AM   #2
OrangeVert
"Catharine"
OrangeVert's Avatar
Drives: '11 2SS/RS LS-3 IOM/IO vert
Can't be good for it. I wouldn't let it, but that's just me. Maybe use a waterproof top cover? But the it should be able to breathe too. I don't know, sorry.
OrangeVert is offline   Reply With Quote
Old 06-15-2014, 07:17 AM   #3
pgustavson
Stop writing "vert", ffs!
pgustavson's Avatar
Drives: 2011 2LT Convertible
I just remove it as soon as I can, though I doubt it will hurt it in most cases. During high-snowfall storms, I carefully sweep it off each time I go out to shovel the driveway. My only concern is allowing a large amount of snow to sit there and go through melt-freeze cycles. I just feel like there would be a higher chance of leaking to occur. No evidence to prove that, just a gut feeling. The wear and tear on a non-garaged top is a bit accelerated over that for the garaged ones, but it is what it is. And it's just a car...
Vararam | Vmax Ported TB | Ported IM | Vmax Black ICE-olator
pgustavson is offline   Reply With Quote
Old 06-15-2014, 07:53 AM   #4
Angrybird 12
7 year Cancer Survivor!
Angrybird 12's Avatar
Mine sat out ll winter, we had several snowfalls in the 6-8 inch range and had no problems except when it melted condensation would build up on the windows and other surfaces. That is from the cold water draining into the water management bag and then the temperature inside the car warming up. What I started doing is when it started melting I would go out and clear the snow off the car and start it to led it dry out inside. I haven't seen any bad effects from that.
The Bird is the word!
Old 06-15-2014, 09:28 PM   #5
theragtopguy
Lifetime Philly Fan
theragtopguy's Avatar
Drives: 2015 Spring Edition 2SS M-6
No problems, had severe winter here in PA, top survived just fine.
2015 Green Flash, Delivered 4/10/15
CAI, NPP Exhaust, Short-throw shifter
BBK LT HEADERS 1 7/8”
Tune by DynoSteve via SCTx4 Tuner
One of 82 GF Ragtops built in '15 out of 811 Total
[/SIZE]
theragtopguy is offline   Reply With Quote
