06-15-2014, 09:47 AM | #1 |
Drives: 2013 ZL1 Join Date: Nov 2013
Blew The Pfadt Cats out
So I got on the gas the other night I hear a loud BANG!!! Sounded like my exhaust flew off. I pull over and look under the car and saw the clamp after the hi Flow cats had come loose so I decided to head home and park it because it sounded like open headers.
The following day I pull the Cat off. At first I could see pieces of metal hanging outside the clamp and after removing the clamp and cat I grab a flashlight and look down the the OEM Pipe and see the cat completely crushed pushed down stuck in the bend of the OEM Xpipe/Cat Back. I Pull most of it out but a large piece was stuck in the bend so I put it back together and drive hoping it would blow through BAD IDEA now it's quiet and whistles must be more in their than I expected. So my question is should I drive it hard or will that mess things up because I'm now at a loss their are no separations in the exhaust so it's not like I can take it apart in Pieces and pull or push crap out right? Car does bog at some RPM's I'm just really scared to get on it ya know? Suggestions. Car is heavily modified we made 635HP on a Mustang Dyno it's running 17# of boost on Methanol. |
06-15-2014, 09:50 AM | #2 |
Drives: 2015 Z/28 #533 Join Date: Jul 2012
Boost destroys cats. Get a set of catless midpipes and you'll be fine.
06-15-2014, 09:52 AM | #3 |
And I found this out the hard way LOLOL.
So can I drive it or will the reduction in back pressure on that one side because of the clog mess things up? |
06-15-2014, 09:53 AM | #4 |
You shouldnt be driving with clogged exhaust. Get something and punch them out.
06-15-2014, 09:54 AM | #5 |
Thanks Mike
06-15-2014, 09:56 AM | #6 |
You're welcome
06-15-2014, 12:18 PM | #7 |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
Here we go, another story of a failed "high flow" cat. I have told many people to leave the Cats off unless you want trouble. Like was stated previously you are going to have to remove the exhaust system and try to get all of that crap out of your exhaust pipes and mufflers. Sorry bro.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
06-15-2014, 01:48 PM | #8 |
Drives: '21 ZLE A10 Join Date: May 2012
cats suck! I have had a JBA fail so they hit the trash.
06-15-2014, 02:53 PM | #9 | |
Ragtop Rocket!!!
Drives: Black on Black Convertible Join Date: Mar 2013
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package. 744rwhp 727rwtq |
06-15-2014, 09:24 PM | #10 |
I blew mine out at the track today! Was advised not to get on it hard and drive as little as possible. Removing mine tomorrow.
06-15-2014, 09:32 PM | #11 | |
Whipped
06-15-2014, 09:52 PM | #12 |
Ragtop Rocket!!!
Put some on get inspection then take them off. It's just once a year thing.
06-15-2014, 10:06 PM | #13 |
Drives: 2011 2ss/rs Join Date: Nov 2011
Pictures!!!
06-16-2014, 10:57 AM | #14 |
Drives: 2016 Corvette Z06 Blade Silver Join Date: Jun 2009
The factory tune has a CAT overheat protection. Many turners disable this feature. I would be curious to know if your tune has this disabled. Ted from Janetty has discussed this in the past. Supposed to be that a good tune with COT you will not blow up the CATs if they are properly sized.
http://www.camaro5.com/forums/showpo...92&postcount=8 Modded cars it is always a challenge getting this to behave like a stock car. For me I don't want my car to smell like an old rusted out pickup truck so CATs are a must.
2016 2LZ Z06 Blade Silver
2013 ZL1 BLACK on BLACK <SOLD> Roto-Fab CAI 2010 2SS/RS BLACK on BLACK <SOLD> 3" MBRP 304 Stainless Exhaust Roto-Fab CAI |
