Silver Bomber
Drives: 2010 Camaro LS SIM Join Date: Feb 2012
FS -Prothane motor mounts
SOLD please delete
☼ BMR Sub-frame connectors, BMR strut tower brace, BMR adjustable sway bars ☼ BC Racing Coil Overs ☼ Vararam Intake ☼ Rx Catch can & Oil cap breather ☼ Brembo's with slotted/drilled rotors ☼ Dynomax VT Mufflers ☼ Trifecta Tune ☼ Hella Fogs ☼ Eagle Eyes ☼ Heritage Grille ☼ Enkei Raijin wheels ☼ Last edited by Cross; 07-27-2014 at 09:06 PM. |
Silver Bomber
Lowered price.
☼ BMR Sub-frame connectors, BMR strut tower brace, BMR adjustable sway bars ☼ BC Racing Coil Overs ☼ Vararam Intake ☼ Rx Catch can & Oil cap breather ☼ Brembo's with slotted/drilled rotors ☼ Dynomax VT Mufflers ☼ Trifecta Tune ☼ Hella Fogs ☼ Eagle Eyes ☼ Heritage Grille ☼ Enkei Raijin wheels ☼ |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 ZL1 416 Join Date: Feb 2013
additional NVH ???
2010 2SS/RS M6
Drives: 2010 2SS/RS M6 Join Date: Jun 2010
Noise, vibration, harshness = you can hear/feel the engine more inside the cabin because the engine is mounted more directly to the frame. The softer stock bushings provide a certain level of shielding from this, but as a consequence the engine is allowed to move around a bit more.
2/7/2014: 419 hp, 419 tq
Cosmetic: ZL1 front w/mailslot, painted stripes, powdercoated SS rims, tow hook, and full chrome delete Suspension: Pfadt subframe bushings, Pfadt rear UCA bushings, Z28 Upper control arms, Spohn trailing arms with BMR trailing arm & differential bushings, ZL1 Toe Rods and springs, Prothane radius arm inserts & steering rack bushing, Pfadt Sport front sway, FE4 conversion w/ DS rear sway, Pfadt strut brace Drivetrain: RMCR tune, CAI intake, Kooks headers, hi-flo cats & exhaust, VMAX TB, ZL1 fuel pump, LSR Tri-Ax shifter Bumblebee Racecar Build |
ok thanks
#6 |
![]() Drives: 2010 Camaro ss Join Date: May 2013
Are these the solid version
#7 |
Silver Bomber
Solid polyurethane and aluminum. Sorry for the slow response haven't checked on the thread in a while.
#8 | |
Silver Bomber
-What he said.
#9 |
![]() Drives: 2014 Camaro SS Join Date: Jul 2014
Pics to greengt88@yahoo.com if possible....interested..thx
2014 Ashen Gray Metallic 2SS/RS M6
CAGS Skip-Shift Eliminator 1LE Strut Tower Brace GMPP Track Pack Axleback Halltech CAI Fuse Pull Mod |
#10 | |
Silver Bomber
#11 |
![]() Drives: Supercharged 2011 camaro ss vert Join Date: Mar 2014
Do you still have these?
