Old 06-18-2014, 05:08 PM   #1
VINNY1980
VINNY1980's Avatar
Drives: 2010 camaro 2ss abm m6 , 2013 zl1
Send a message via AIM to VINNY1980
2010 camaro ss
I have a 2010 camaro ss manual ls3. If i get it rolling should i be able to break tire loose by just flooring it? I dont want to i just want to make sure. When i take off on roll and gas it it kind of sluggish for second then takes off. I have long tube headers high flow cats borla atak cat back adm cai. I think has tune because of no check engine light and no 1-4 skip shift. Just want to make sure its right.
Thanks Tom
VINNY1980 is offline   Reply With Quote
Old 06-18-2014, 05:19 PM   #2
KTMracing09
KTMracing09's Avatar
Drives: 2SS/RS L99 ABM
I have an auto and if I put my car in 1st, roll at about 15 mph and then floor it I'll spin through the rest of 1st gear and chirp 2nd gear with traction control ON. So I would assume a m6 could. As for sluggishness, get a ported throttle body, will make the throttle response better
Rotofab CAI, 2" LT Headers/non catted, 3" Straight Pipe w/ X-Pipe, Elite Catch Can, GPI SS3 VVT, 9" 4000 Triple Disc, Yella Terra Ultralite Rocker Arms, MSD Super Conductor wires
KTMracing09 is offline   Reply With Quote
Old 06-18-2014, 05:32 PM   #3
6 gun
Drives: 2010 ss 6 gear
Dude... my car really isn't that every. I got a 010 ss. In getting gears... LS 7 clutch.... small cam. Then I will decide to keep it. Don't forget these things are heavy
6 gun is offline   Reply With Quote
Old 06-18-2014, 05:42 PM   #4
VINNY1980
VINNY1980's Avatar
That what i thought that if i mash it to floor in should want to break loose. Maybe ill just have to get tune looked at. I bought with all theae mods done already from dealership. Maybe they did something to tune ? And yes i was looking at ported throttle body also. I thought it was strange that it wouldnt break loose.
Old 06-18-2014, 06:03 PM   #5
OHIOSS
Russ
Drives: Yukon Denali, Charger, CamaroSS
Send a message via AIM to OHIOSS
Change your rear gears to 3.91, I can spin the tires in 2nd gear. I can be going 20MPH and floor it in 2nd and the tires will spin until I let off of the gas. I've also had a tune done so I'm sure that helps also. The difference in the gear change was even better than I hoped it would be. I highly recommend it!
Russ
OHIOSS is offline   Reply With Quote
Old 06-18-2014, 08:13 PM   #6
KTMracing09
Since you don't know if it is tuned or not I would say try a fuse pull, couldn't hurt to try
Old 06-18-2014, 09:25 PM   #7
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
Thanks Tom
You have a lot working against you with these cars as they were designed to put the factory power to the pavement and avoid lighting them up. 3.45 gears, independant rear suspension, 275/40's, traction control/stabilitrac. I have read that TC/stabilitrac will maintain properties even when shut off, but I'm not 100% sure about that. I have a 2011 2SS m6 and for me to get to where I can just punch it at resting idle and smoke the tires, I needed full exhaust, intake, cam, 4.10 gears and ported/modded throttle body, and obviously tune. I'm at about 450 rwhp now. I don't drag race, so I prefer smoking them tires too
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 06-18-2014, 09:36 PM   #8
stlrammer
Drives: 2017 1SS Blue
I just traded my 1SS LS3 after 3 years of great memories. It would smoke the tires under the conditions outlined above and get scratch in second too. It didn't realize it was over weight and had wide hips.
In all fairness I ran General GMax AS tires in place of Pirelli sticky summer tires so lighting them up was less of a challenge.
stlrammer is offline   Reply With Quote
Old 06-18-2014, 09:59 PM   #9
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I know you guys are focused on manual shift but I just wanted to chime in, even though I have an automatic. In the colder weather (40s-50s) I can get a little wheel action from a stand still, but this time of year... even with the nannies off I barely get any wheel spin. These P-Zeros stick like glue when the temps are above 65 or so. I don't particularly want to burn up my tires, so that's okay, but I do like to play every once in a while. And my car is no dog - she'll flat get up and go. Factory tires, nannies, gears = built to get the metal moving forward ASAP.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 06-19-2014, 05:50 AM   #10
VINNY1980
VINNY1980's Avatar
Thank for the replies. Not want to smoke tires. But have some fun sometimes. Also i have the 21 inch wheels. That probably dont help either.
Old 06-19-2014, 07:31 AM   #11
ytown87
ytown87's Avatar
Drives: C6 Corvette
I have pretty much same mods as you and ever since the increase in power it always spins in 1st gear with traction control off. Any rpm any speed until second...and then it will spin some more. One time rolling on the interstate around 80 I mashed the gas down and broke loose. Traction control was off and I was driving him from the track on my DR. Just be careful when you floor it with no TC on. The 21's may hold all that back though.
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 06-19-2014, 07:39 AM   #12
ytown87
ytown87's Avatar
Drives: C6 Corvette
Where are you in Florida? Wouldn't be a bad idea to find out who did your tune, if it is custom, in case you do more and want the person who has all the car info saved. That is if it is a FL car. If so, hopefully Phil did it.
Old 06-19-2014, 04:56 PM   #13
VINNY1980
VINNY1980's Avatar
Im in spring hill 45 minutes north of tampa. Bought car in clearwater. Dimmit chevrolet on us 19. Yea i was thinking of going to tampa tuning to have tune looked at and maybe ported tb.
Old 08-31-2014, 02:23 PM   #14
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
This car was seriously jacked up with a piss poor tune. I saved it yesterday from certainly a failure.
Tampa Tuning is offline   Reply With Quote
