Old 06-26-2014, 10:09 PM   #1
codeman1736
codeman1736's Avatar
Drives: 2011 camaro 2ss
Putting straits on a 2011 camaro 2ss
I have a question about putting strait pipes on a 2011 camaro 2ss. It's manual 6 speed of course with the LS3. My question is has anyone done this and had any tuning problems or power loss? Maybe even the car running rich? I haven't done it yet but wanted to do my research before doing it. I will be leaving the cats on though. Any input on it with or without cats? Does it need to be re tuned after doing it?
codeman1736 is offline   Reply With Quote
Old 06-26-2014, 10:11 PM   #2
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
You have straight pipes on it now, besides a H pipe. What exactly are you trying to accomplish?
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 06-26-2014, 10:29 PM   #3
codeman1736
I'm trying to take off the mufflers and run it strait out with diffrent tips. May go up on size of pipe running out. I don't have it yet. I just want to make sure I won't have any issues if I do.
Old 06-26-2014, 10:40 PM   #4
axis
Search Ninja
axis's Avatar
That's not straight pipes, that's called a muffler delete. LOTS of people on here have done it. Just search for muffler delete in this section or in google. Google will probably redirect you back here, lol. Several companies make a version of the muffler delete that comes with tips, or you can just have a muffler shop do it. There are no issues by going without mufflers, other than a lot of sound. Some like it, some don't. Personally, it's not for me. There is no performance benefit by going without mufflers and no tune is needed. The OEM exhaust flows extremely well, it's just too quiet.
Halltech CF 102 fed
Old 06-26-2014, 11:00 PM   #5
codeman1736
How loud are we talkin? Iv always called them straits I never knew it was called a muffler delete. Iv had it done on a truck before and iv also had flows on another. But iv never done it to a motor of it's this size.
Old 06-26-2014, 11:04 PM   #6
axis
Search Ninja
axis's Avatar
From what i've seen posted, it's not too bad at idle and cruise but is quite loud when you get on it. It will induce drone, no matter what anyone says. The OEM mufflers have j pipes in them that are there for that very reason. Once you take them out, the drone comes back. That's not a issue for some, but is for others. Look in the sticky section. I'm sure you'll see a thread that has what you're looking for in it.
Halltech CF 102 fed
Old 06-26-2014, 11:07 PM   #7
codeman1736
I'm not sure what you mean by a drone
Old 06-26-2014, 11:36 PM   #8
axis
Search Ninja
axis's Avatar
Drone is a frequency in the exhaust in which the car will vibrate a little and there will be a constant tone inside the car. When it's in the 1700-2000 rpm range (cruising), it can wear on you. Not usually an issue driving around town, but get on the highway and it can become unbearable after an hour or so.
Halltech CF 102 fed
Old 06-27-2014, 12:13 AM   #9
codeman1736
Oh ok I know exactly what u mean by that. My f150 use to do that but it wasn't bad. Thank you a lot on this. It's helped me a lot.
Old 06-27-2014, 08:29 AM   #10
Spoolin
Drives: 2014 SW 1LE
Straight pipe is terminology when you are replacing the cats with a striaght pipe. Muffler delete is when you are replacing the Muffler with a straight pipe.
Will be loud and will drone, other than that it will be awesome!
Spoolin is offline   Reply With Quote
Old 06-27-2014, 09:10 AM   #11
ytown87
ytown87's Avatar
Drives: C6 Corvette
Car will be extremely loud! Drone will be very loud! Depends if you like that or not, if cops in your area will care, if your neighbors will hate you every morning and night you start it up, if you have passengers you like to carry on conversations with..things like that. Why not just add cutouts and be able to choose when the car is normal or killer? Regardless what you do..I highly recommend a set of long tube headers to make the car sound a lot more of a muscle car.
2008 C6 m6. Carbon creations front/rear carbon fiber wodebody fenders. Carbon fiber hood carbon fiber roof hoop carbon fiber zr1 extreme spoiler. NW 102mm tb. Ported intake manifold. Cometic .040 head gaskets. LG motorsports G6x3 cam. DSX flex fuel sensor. AEM methanol kit. Z06 brakes. Ebiach sway bars. ZR1 rep wheels and Nitto Invo tires. Monster stage 3 twin disc clutch. MGW short shifter. Corbeau race seats. Gforce race harnesses. SLP loudmouth 2 mufflers. Carbon fiber exhaust tips. RPM stage 4 transmission and Stage 3 rear diff. 3.73 gears. Vararam cai. Kooks 1 7/8 headers and x-pipe.
ytown87 is offline   Reply With Quote
Old 06-27-2014, 11:12 AM   #12
codeman1736
I really want a set of long tube headers but man are they expensive.
Old 06-27-2014, 12:04 PM   #13
djpelosi
djpelosi's Avatar
Drives: 2010 Camaro 2SS/RS
The term straight pipes means you are running exhaust from the manifold/header straight through exhaust pipes only with no other restrictions. No cats, no resonators, no mufflers. I am running this setup right now with longtube headers and it's not that bad. It's very loud at wide open throttle, but it's not obnoxious at a cruise or idle. If you remove the cats, you won't "require" a tune to drive it, but a tune is recommended because it will throw a check engine light, which can only be removed by tuning. Plus it will get you a few more horsepower. I actually have a similar setup I'm selling that will give you a great sound and more HP. I'll PM you the details.
2010 Camaro 2SS M6
2" Stainless Power Longtube Headers
3" Full exhaust w/ Off-Road H-Pipe
Bo White Ported Throttle Body
Hurst Short Throw Shifter
Best Time: 12.43 @ 114, 1.99 60' on stock wheels and stock tires
Build Thread
djpelosi is offline   Reply With Quote
Old 06-27-2014, 12:10 PM   #14
NYYFan325
I have a muffler delete on my car (was actually like that when I got it). It's actually not terribly loud at all and sounds quite good.
NYYFan325 is offline   Reply With Quote
2ss camaro, exhaust, ls3 5thgen, strait pipes, tuning advice
