Old 06-28-2014, 04:47 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Tool for wicker bill rivnut and installed
We now have a inexpensive riv nut tool we had made to install our wicker bills.
Skylane765 is offline   Reply With Quote
Old 06-28-2014, 04:54 PM   #2
Mikebrinda
Mikebrinda's Avatar
Drives: Ferrari F430 Spider F1 Azzurro Arge
That's a good call.
Mikebrinda is offline   Reply With Quote
Old 06-28-2014, 05:25 PM   #3
tw78911sc
tw78911sc's Avatar
Drives: 14 1SS Camaro 1LE, NPP, Recaros
brilliant, thx
tw78911sc is offline   Reply With Quote
Old 06-28-2014, 06:18 PM   #4
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Nice!!
Angela
350 HRSS is offline   Reply With Quote
Old 06-28-2014, 06:19 PM   #5
350 HRSS
GM Toyz Lover
350 HRSS's Avatar
Drives: GM Toyz
Post pics of the install! I have mine, getting it put on next week!
Angela
Old 06-29-2014, 09:14 AM   #6
Spoolin
Drives: 2014 SW 1LE
I've got three Nut-zert guns and I use them on anything and everything, it's one of those tools that if you have one, you wonder what you'd do without it.
Spoolin is offline   Reply With Quote
Old 06-29-2014, 12:55 PM   #7
Skylane765
Skylane765's Avatar
I do also, but most do not, yes you can live with out them by just using a nut a washer and bolt. Most do not have the tool. I my self do not like rivnut a to begin with. I just used the bolt method because I did not want to drive to the hangar that day and only a few where installed.
Old 06-29-2014, 01:09 PM   #8
danvillekidd
2013 ZL1
danvillekidd's Avatar
Drives: 2013 ZL1 m6
I've had to do that more than once as an aircraft mechanic. Most of the time it seemed that someone had broken the tool whenever I needed it. For those not familer with this, hold the bolt and tighten the nut. I usually used a hex head bolt, but anything that you can hold still works.
danvillekidd is offline   Reply With Quote
Old 06-29-2014, 02:27 PM   #9
Skylane765
Skylane765's Avatar
Because of plastic, use a piece of strap and use it as a washer, with out it the riv nut will spin. Got mine all in no problem. Never tighten the bolt, only the nut and hold the strap/washer
Old 06-29-2014, 02:40 PM   #10
Skylane765
Skylane765's Avatar
Pic of the job done
Old 06-29-2014, 02:49 PM   #11
Skylane765
Skylane765's Avatar
All done
Old 06-29-2014, 03:02 PM   #12
Skylane765
Skylane765's Avatar
Better look at DIY tool, no need for the $200 tool unless you have one. I have one and made this one quicker than diving and getting the tool.
Old 06-30-2014, 07:51 AM   #13
mikeg
Drives: 1974 Z28 & 2014 Z28
great post!
maybe a stupid question...can you over tighten the nut with the wrench turning on it...how do you tell when the riv nut is fully compressed?
thanks
mike
mikeg is offline   Reply With Quote
Old 06-30-2014, 08:29 AM   #14
backtotintops
backtotintops's Avatar
Drives: 14 Z/28 0#
+1
"PTM11" Search & Destroy
backtotintops is offline   Reply With Quote
