Old 06-30-2014, 01:32 AM   #1
Dennis Northwest
Drives: 16 1SS A8 NPP
Elite Engineering Catch Can Installation Question
I have been lurking for years but finally joined the forum and am making my first post due to a question about installing a catch can. As background, I bought a 2 LT new in 2011 and traded it for a new 2014 2SS/RS last April.
Does the belt/pulley tension bolt have to be torqued to a full 50 pounds after installing the catch can bracket? Should I have used the locking washer on the bolt? I installed an Elite Engineering Catch Can on an LS3 motor. Figure 3 of the instructions says to torque the belt/pulley tension bolt to 50 pounds but I was afraid of stripping the threads so I never got to the full fifty pounds. The bolt feels way tighter after I put it on then it did coming out. Also, I noticed the locking washer after the installation was completed and it was not included in the instructions. Am I ok not using the locking washer and not torquing the bolt to a full 50 pounds?
Dennis
Dennis Northwest is offline   Reply With Quote
Old 06-30-2014, 10:41 AM   #2
sscamaro
Drives: 2010 2SS, 2017 Silverado LTZ
If they recommend doing that, then I would do that.
sscamaro is offline   Reply With Quote
Old 06-30-2014, 10:57 AM   #3
Dennis Northwest
I agree but my concern is that I may strip the threads before I hit 50 pounds of torque on the bolt. Also, the lock washer was not included in the instructions but was provided. I am hoping that somebody who has done this mod can weigh in with some advice. I am not the best mechanic but I know what it feels like to strip threads and it feels like I'm almost there. Thanks.
Dennis
Old 06-30-2014, 11:04 AM   #4
PalmerGA
PalmerGA's Avatar
Drives: 2013 SIM 1SS/RS L99
I would think you should use the locking washer that was on there, unless the instructions specify "Do not reinstall locking washer". Also, as stated above, if it say "torque to 50 psi" I would certainly do that.
Or... contact Elite for clarification:
sales@eliteengineering.com
I looked at the install directions on the site and they are a little sketchy. Better contact them to be sure.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
PalmerGA is offline   Reply With Quote
Old 06-30-2014, 11:07 AM   #5
sscamaro
I'll check my manuals to see what the torque should be.
Old 06-30-2014, 11:41 AM   #6
sscamaro
The manual actually says 59 ft lb.
Old 06-30-2014, 06:44 PM   #7
Dennis Northwest
Thanks for the help. It looks like I will have to pull the bolt, place the lock washer on and torque it to 50 pounds.
Dennis
Old 07-01-2014, 01:13 PM   #8
K1SSRSS
Chief Many Camaros
K1SSRSS's Avatar
Drives: A paid off Camaro!!!
Are you sure your Tq. wrench is accurate? I recently found out how much of a PITA it is when a Tq. wrench does not function properly.
504hp/478tq
Performance: Kooks LT, 3'' Exhaust, V-Max TB, Roto-Fab CAI, Custom Ported/Port Matched Heads and Intake
Suspension: BMR Adjustable LCA's, BMR Trailing Arms, Poly Bushings, BMR Toe Rods
Coming Soon (still in the box): Procharger F1R, G-Force Axles, 3:91 gears w/Eaton Truetrac
K1SSRSS is offline   Reply With Quote
