Old 06-30-2014, 02:23 AM   #1
songsj
Drives: 2015 2SS/RS Summit White
What is the advantage
I have a 2013 2LT/RS. It came with 275/40/20 on the rear and 245/45/20 on the front. What is the advantage to the larger rears. I'm just thinking it may be easier for me to go with all the same size when replacement time comes. Thoughts?
songsj is offline   Reply With Quote
Old 06-30-2014, 04:19 AM   #2
fly2hip8
Drives: 2013 Camaro 2SS
Better traction and looks.
fly2hip8 is offline   Reply With Quote
Old 06-30-2014, 07:41 AM   #3
MYDLIFECRISIS
MYDLIFECRISIS's Avatar
MYDLIFECRISIS is offline   Reply With Quote
Old 06-30-2014, 08:24 AM   #4
2012LS3VERT
Drives: 2012 2SSRS Vert, Black w/M6
It would look kinda goofy with 245s in the rear on a Camaro, whether it was a V8 car or not. If you wanted a set you could rotate, just get a set of rear wheels to put in the front and run 275s all the way around. In case you weren't aware, your rear wheels are wider than the fronts.
2012LS3VERT is offline   Reply With Quote
Old 06-30-2014, 12:28 PM   #5
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
This They still tuck in and look offset because of the rear fenders, but they can be rotated which is a plus.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
