Old 06-30-2014, 09:56 AM   #1
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr
Anybody try x10" width with a 315/35?
I am fast approaching the need to change rear tires again and wanted to step up this time to the 315/35, but the wheels in the price range i want are only going up to 10" width not 10.5" or 11". So, anybody running them on the smaller 10" width? How is the handling?
Sold 2012 2LT RS 12.3@112 old setup
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS.
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47**
Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver
Daily Driver 2021 BMW M340i Xdrive
IneedAZ is offline   Reply With Quote
Old 06-30-2014, 12:20 PM   #2
MillerTime
Blowin the doors off!
MillerTime's Avatar
Drives: A 2013 SS RS 6M SR
I'm running them on a 20x10 with 37mm offset. Handling is fine and they REALLY hook. Nitto 05's. I also went a little wider with 8.5's in front as well.
2G1FS1EWXD9163847
MillerTime is offline   Reply With Quote
Old 06-30-2014, 12:26 PM   #3
IneedAZ
IneedAZ's Avatar
thanks for the info
Old 06-30-2014, 12:43 PM   #4
MillerTime
MillerTime's Avatar
Your welcome. There is no bulge either btw, it's not oversized.
2G1FS1EWXD9163847
Old 06-30-2014, 12:55 PM   #5
kcsr6
kcsr6's Avatar
Drives: 2011 Black LS3 2SS/RS
I'm running a 315 35 on a 10.5 wheel
2011 2SS/RS, Torch Red Bow Ties, 5% Tint, Oracle Side Markers, Forgestar F14's, Pfadt lowering springs, Vararam Intake, VMax Throttle Body, Custom Grind Comp Cam 224/236 114, SLP Under Drive Pulley, Granatelli Wires, Kooks 1 7/8 LTH, Off-road pipes, 3" exhaust, Mike Norris Motorsports Tune 471 RWHP 449 RWTQ! Search for kcsr6 on YouTube for sound clips.
kcsr6 is offline   Reply With Quote
Old 06-30-2014, 03:11 PM   #6
VR Baron
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE
315 Nitto Invo bulges on 10" rim. Not sure how it hurts handling if any but squished and soft sidewall not optimum. Just changed out to 285/35PSS's
VR Baron is offline   Reply With Quote
Old 06-30-2014, 08:22 PM   #7
ST1LE
ST1LE's Avatar
Drives: E92 BMW M3
10.5" is really the minimum you want to go with on a 315 tire. I would stick with 305 for sure!!
SOLD - 2013 1LE - Pat G Spec'd Cam, NPP with 1 7/8" Long Tube Headers with High Flow Cats, Intake w/scoop, Ported Throttle Body, and Apex 1.25" Lowering Springs.
J-Rod Built and Matt@FSP Tuned
ST1LE is offline   Reply With Quote
Old 07-01-2014, 09:24 AM   #8
IneedAZ
IneedAZ's Avatar
That is what im thinking, cause i know how i drive on the curve roads to/from work and want to keep traction optimal.
Old 07-02-2014, 12:06 AM   #9
MillerTime
MillerTime's Avatar
Stick out how? It does not bulge... It is completely vertical...
2G1FS1EWXD9163847
Old 07-02-2014, 12:29 AM   #10
VR Baron
315 invo on a 10" rim definitely bulges outward. I tried meassuring and was bulging out about 1/2" past the rim lip.Not bad, the 275 invo on a 9" rim bulges out 1/4" and thats factory size wheel/tire combo
Old 07-02-2014, 09:59 AM   #11
IneedAZ
IneedAZ's Avatar
Well, i am either going back with the Vredesteins again or swapping to the Michelin. I know sizes change from brand to brand, but unless i find a 10.5" or 11" in my price range i will probably have to go smaller then the 315
Old 07-03-2014, 05:41 PM   #12
MillerTime
MillerTime's Avatar
I guess it depends on the wheel their going on. Mine don't bulge. There is the manufacturers lip that sits inside the wheel and then it's completely vertical on mine...
2G1FS1EWXD9163847
Old 07-04-2014, 09:11 AM   #13
EmeryZ28
EmeryZ28's Avatar
Drives: 2011 Camaro 2SS/RS LS3
technically they say it is not the right size match, but I have 315's on 10.5 and they fit perfect. So I would assume on a 10" there would just be a small amount of bulge. Many people on here are running 315 on 10s
2015 Silverado Z71 6.2/2011 Camaro 2SSRS LS3/2014 Cadillac ATS 2.0T
EmeryZ28 is offline   Reply With Quote
Old 07-04-2014, 09:59 AM   #14
YLWJKT
Drives: 2017 ZL1
I jist sold my stock wheels that were widened to 10.5 and 315's fit very well.
YLWJKT is offline   Reply With Quote
