Old 06-30-2014, 01:54 PM   #1
AuburnGrad93
AuburnGrad93's Avatar
Drives: 2018 Ford F-150 Lariat 4x4
Amp/Sub question on 2012 Convertible
So I've been searching the threads both here in the Vert section and the radio section and everything seems to be older posts? So I was wondering what Amp/Sub combination people are using more recently? I am just wanting to upgrad the Amp and sub but keep the stock look and all my trunk space. Have tried to call ******** but no answer? I have the MyLink NAV radio with BA and am very happy with it, just wanting to improve the sound a little bit. Also, not wanting to spend a mint here either! Just a decent amp/sub combination?
1999 30th Anniversary Convertible Trans Am
2001 SOM Convertible Trans AM
2012 2SS/RS Summit White Convertible
My Build Thread: http://www.camaro5.com/forums/showthread.php?t=224339
AuburnGrad93 is offline   Reply With Quote
Old 07-02-2014, 09:26 AM   #2
AuburnGrad93
No one has a suggestion???
Old 07-02-2014, 09:40 AM   #3
45thCamaro
45thCamaro's Avatar
Drives: 2012 Camaro 45th Anniversary RS
I do not have a vert, but the JL 400/xd I believe is popular. Not sure of figment issues with the vert trunk however.
45thCamaro is offline   Reply With Quote
Old 07-02-2014, 10:47 AM   #4
VOLmanTN
Go Vols!
VOLmanTN's Avatar
Drives: 2011
I am planning on using the ******** harness and attaching a powered bazooka sub in the trunk. I've had friends with these in the past and they always sounded good and can easily be removed for space. I like that the bazooka is just one tube with amp built in.
VOLmanTN is offline   Reply With Quote
Old 07-02-2014, 04:12 PM   #5
AuburnGrad93
I also plan on using the ******** harness, but I am thing of just replacing my stock Amp with a 5 channel Amp and then replacing my stock sub behind the rear seat with an aftermarket sub. I have pretty much narrowed the amp down to either the JL XD700/5 or the Alpine MRX-V70? Just no one knows a model number of the sub that will fit in the Vert stock location?
Old 07-02-2014, 11:13 PM   #6
LuckyZL-1
Ragtop Rocket!!!
LuckyZL-1's Avatar
Drives: Black on Black Convertible
Go with JL audio! I did Kicker my buddy did JL and his rocks! I'm switching mine out soon.
ADM built 2013 Triple Black ZL-1 Convertible M6
ADM custom cam, LPE stage 2 heads with dual valve springs, LS-3 ported throttle body, LPE 2 piece pulley, LPE overdrive balancer, 10% overdrive pulley, ported supercharger inlet, ADM race intake system, stainless works 1-7/8 headers, Injector Dynamics injectors, ADM heat exchanger, ADM dual fuel pump system, ADM exhaust switch, ADM 3 tunes tuning package.
744rwhp 727rwtq
LuckyZL-1 is offline   Reply With Quote
Old 07-03-2014, 01:16 PM   #7
AuburnGrad93
Yeah, I have decided to go with the XD700/5 for certain. Now just need to decide on which sub I need? Has to need less than 7" clearance from what I understand?
Old 07-03-2014, 01:52 PM   #8
xnuyokr
xnuyokr's Avatar
Drives: 2012 1LT Drop Top
I went with this 10":
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 You need the adapter plate from sub thump since the original sub is 8"!
xnuyokr is offline   Reply With Quote
Old 07-03-2014, 10:27 PM   #9
AuburnGrad93
So you're happy with it? And it fit in the stock location behind the rear seat without any problems? Did you add any sound deadener behind it or anything?
Old 07-03-2014, 11:42 PM   #10
xnuyokr
xnuyokr's Avatar
Perfect fit (with the adapter). I lined the whole enclosure with Fat mat and also used Pillow fill on either side to reduce the size of the space. I haven't upgraded my stock amp yet,(non Ba) and I wired the sub for 1 ohm operation and it's a great improvement. It should sound even better with your BA amp!
