MikeNoMaro
Drives: A 2016 Challenger R/T M6 STP Join Date: Sep 2009
System too lean
Cel P0171 just came up.
I think my hi flow cats might have something to do with it. Removed the rear 02 reading with my ITSX, doesnt work. tried adding fuel at WOT by 4%, still popping back. what else?
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016. |
MikeNoMaro
Found these to do to most likely solve the issue:
• Clean the MAF sensor. take it off and spray it with electronics cleaner or brake cleaner. Make sure you are careful not to damage the MAF sensor, and make sure it's dry before reinstalling • Inspect all vacuum and PCV hoses • Inspect all hoses and connections in the air intake system • Inspect and/or test the intake manifold gaskets for leakage especialy the Driver side. • Check for a dirty fuel filter and proper fuel pressure • Ideally you'll want to monitor short and long term fuel trims using an advanced scan tool • If you have access, you may want to run a smoke test
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Popping on decel is the result of the DFCO kicking in, (Decel Fuel Cut Off). IDK if that's what you mean or not. DFCO can be tuned out.
#4 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Vacuum leak or Exhaust leak are more likely the culprits. Aftermarket Cold air kits need varying degrees of calibration to keep fuel trims in check. This code will not set at WOT it sets in closed loop when fuel trims exceed 12% Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
MikeNoMaro
The only thing I can think of that could be the culprit is the fact that last august I've re-oilled my K&N air filter...I might of been too generous. So tomorrow Im getting the MAF sensor clean and will check for any leaks.
#6 |
MikeNoMaro
Yep! Case resolved. Dirty MAF cause cel P0171 System too lean.
thanks guys.
#7 |
MikeNoMaro
Well, I might of spoke too soon. I drove 150miles without any CEL since cleaning the MAF & Inspecting all vacuum and PCV hoses last friday.
This morning 2 new CEL showed up with the same as before: P0133 O2 Sensor Circuit Slow Response (Bank 1 Sensor 1) P0171 System too Lean (Bank 1) P1134 Oxygen Sensor Circuit - Transition Switch Time Ratio (Bank 1 - Sensor 1) I'm bummed and running out of explanations...but the funny thing is that the car seems to run better with the code, it seems to pull harder.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016. Last edited by Mikamaro; 07-09-2014 at 10:07 AM. |
#8 | |
Ted.
#9 |
MikeNoMaro
First thing I've done weeks ago when the Cel P0171 came at first, replaced both pre-cat with new O2 sensors.
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016. Last edited by Mikamaro; 07-09-2014 at 01:23 PM. |
#10 |
MikeNoMaro
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
I starting to think I might have a wiring problem with the connector to the Bank 1 sensor 1
#11 |
MikeNoMaro
I left the car to my local shop.
We will see what he ahs to say...
#12 |
MikeNoMaro
It seems there was a small leak, They tighten the connection from the Hi-Flow cats to the Manifold. Let's see if that is/was the problem...If the Cel comes back, we will change the Gasket next.
#13 |
MikeNoMaro
The CEL came back, The consensus is that it's because of a bad, weak or flaky MAF sensor. I ordered one. We'll see...
#14 |
MikeNoMaro
Got the new MAF sensor in last night...after about 20 miles of driving, Lean codes came again..
P0171 System Too Lean (Bank 1) P0174 System Too Lean (Bank 2) So perhaps it's time for a tune for my hi flow-cats...
