Old 06-30-2014, 10:05 PM   #1
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
SS Brake Rebuild Kits
Hey Guys, I bought a complete set of Brembos off an SS and before I put them on my car, I want everything to be like new and replace the rubber bits. Where are guys getting rebuild kits for our Brembo Calipers. I would want to do both the front and rear.
Thanks
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 07-01-2014, 10:09 AM   #2
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Found rear caliper kits on Amazon-
http://www.amazon.com/gp/part-finder...sNode=46208011
Be sure to confirm what you buy will fit. Also, depending on the condition of your Brembo's, this is one of those jobs I'd put on the "if it ain't broke- don't fix it" list. You can always easily remove a caliper later if a problem occurs and it's not like these brakes are terribly old.
Just my 2 cents. Make'em look pretty and keep fresh DOT4 in the lines, and they should last a good while.
Old 07-01-2014, 05:20 PM   #3
caverman
caverman's Avatar
Drives: '69 SS Convertible
And go ahead and put some stainless steel lines on them while your at it.
Build Journal
Old 07-01-2014, 06:02 PM   #4
JohnZ
JohnZ's Avatar
I already have the stainless lines ready to go, as well as new pads and freshly turned rotors. Last part of the equation are these seals and some eibach spacers for the wheels.
Old 07-02-2014, 12:37 AM   #5
intensifi
Drives: '12 2LT Convertible
racing brake
http://www.racingbrake.com/category-s/7059.htm
Mods: GM Locking Gas Cap, RS License Plate Frame, SS Brembos, ZL1 FrontEnd, 14/15 Convertible Top
intensifi is offline   Reply With Quote
Old 07-02-2014, 02:53 AM   #6
JohnZ
JohnZ's Avatar
Thanks for the link. How is it soooo Expensive!?
Old 07-02-2014, 12:56 PM   #7
OmniCamaro
US Veteran
OmniCamaro's Avatar
Drives: 2011 Silver Ice Metallic 2SS/RS A6
Exactly. That's too much for the everyday owner.
Dear Lord, give me the strength to carry on despite my Camaro addiction!
JRE iTSX tune, full cat-less Dynatech exhaust, CAI intake, Stillen Slotted/Drilled Rotors, RB braided brake lines, BMR lowering springs, (reserved for definite future MODS)
OmniCamaro is offline   Reply With Quote
Old 07-02-2014, 01:11 PM   #8
intensifi
lighter weight and durability at high heat.
The OEM stuff is fine for a daily driver.
Do be aware new calipers with new all new parts are available on Amazon for way less than the dealer.
If I had it to do over again, I'd go that route. Why rebuild when you can buy new?
Old 07-02-2014, 03:02 PM   #9
JohnZ
JohnZ's Avatar
I don't think you buy Brembo calipers that cheaply. I am not rebuilding my v6 brakes. I am installing the 4 piston and 2 piston brembo calipers.
Old 07-02-2014, 03:52 PM   #10
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Amazon sells the SS's for 130-150...each.
fwiw- the SS calipers are all 4 pistons
Lil' Nasty is offline   Reply With Quote
Old 07-02-2014, 04:34 PM   #11
TBone
Negative Camber Junkie
TBone's Avatar
Drives: 2010 1SS LS3/6MN ABM 1 of 23
You can get the same rubber seals for the pistons that Amazon sells at your local Advanced Auto. Same'ish price and local.
T.
"Horsepower is something that looks great in a Magazine article, but suspension is what actually gets you around the track fast.." Jack Olsen
The drag strip is like sniffing glue, it's cheap, it's a decent buzz, it doesn't last long and they are all the same.
Road racing is like China White Heroin, the buzz is stronger, the high lasts for hours, it's extremely addictive and they are all different.
I can't wait for my next
Track fix.
DA HAWKS OWN DA CUP!!!!!
TBone is offline   Reply With Quote
Old 07-02-2014, 06:38 PM   #12
OmniCamaro
US Veteran
OmniCamaro's Avatar
T.
Part numbers would be beneficial.
Old 07-02-2014, 07:27 PM   #13
JohnZ
JohnZ's Avatar
O'Reilly should be able to look up the parts numbers right? Like they do with oil filters
