07-01-2014, 09:03 AM | #1 |
Drives: 2010 Camaro SS Join Date: Jun 2014
car feels slow 0-60... tq management/powerhop?
Im working with a 2010 camaro ss m6 with longtubes, 3" catback and a CAI tuned by SWG Automotive. I took it to the track last weekend and averaged 2.0-2.1 60 fts (best was a 1.92 60ft) on stock tires and suspension but I could feel the car slack off immediately after launching. First gear on every run felt slow, and then took off once I got into 2nd. the best run I managed was a 13.07 at 109 mph. Ive been drag racing for years and just cant figure it out. Did any of yall have a similiar problem? Do I need to turn off tq management and powerhop all together or just reduce the settings? I really feel like with a full pass the car would easily run mid 12s at 114 or so.
07-01-2014, 02:18 PM | #2 |
PHAT B33
Drives: 2012 TF3 Camaro 2SS/RS M6 Join Date: Jun 2012
Yep, get rid of all the nannies. It'll help.
No wheel hop here since installing BMR subframe connectors & rear trailing (spherical bearing) arms.
07-02-2014, 03:00 PM | #3 | |
Both traction control and stabil trac lights will come on the dash and all the Nannies are Shut off. Ted.
www.jannettyracing.com
07-02-2014, 03:56 PM | #4 |
I did that. 60ft improved with everything off but still felt loss of power after launch. best way I can describe it is a laggy turbo setup where you launch on boost then it takes forever to get going again. It's been a few years since my last drag car but I've never had this much trouble. The tuner said he adjusted the tq management imwhen he tuned the car but hed mess with it some more. he also theorized that the aluminum K&N CAI might be causing high IAT's and pulling timing until the car starts getting cool air around 50-60mph. I tried icing the intake manifold and intake tube but it didnt really seem to make a huge difference.
07-02-2014, 05:41 PM | #5 |
PHAT B33
Turning off the TC & Stabilitrack still leaves the stock tune tq management in place. Sorry, but to get rid of it you gotta tune it.
Under 3k rpm there is a lot of restriction stock. See attached.
07-02-2014, 06:06 PM | #6 |
Drives: 2011 2ss/rs Black l99 Join Date: Jan 2014
So what does a tuned layout look like?
07-02-2014, 09:32 PM | #7 |
PHAT B33
Whatever you wish, I maxed out the tables on mine and let my right foot control it.
07-03-2014, 09:49 AM | #8 |
did you leave the powerhop alone? whats the difference netween powerhop and tq management
07-03-2014, 01:24 PM | #9 |
PHAT B33
Powerhop senses the oscillation of load from the wheel hop and closes the throttle to stop it. I disabled it also, only nanny I left in the tune was oil starvation.
07-03-2014, 10:21 PM | #10 |
hm. well the tuner said he already had disabled TQ management completely so there goes that theory. I decided to change out the cai from the aluminum K&N typhoon to a LMR CAI thats plastic/carbon fiber wrap. The tuner theorized that maybe heat soak/high IAT's are pulling timing until I get up to 40-50mph and cool air starts flowing. The K&N does get HOT to the touch.
07-06-2014, 08:48 AM | #11 | |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
Tampa Corvette Camaro CTV GTO SS tuner
The other side of the coin, why does your feel faster in the colder months. Obviously colder denser air, but your calibration starts to add timing below 59 degrees IAT. Phil |
07-07-2014, 08:23 AM | #12 | |
Ted.
07-08-2014, 09:15 AM | #13 | |
Senior Camaro Fanatic
Drives: 2011 SS/RS manual - White Join Date: Aug 2010
Thank-you for this informative post
Former '68 and '69 Z/28 Owner...........Now sporting around in a 2011 RS/SS with........Kooks LT's and cats, JRE tune, CAI, scoop, ZL1 Bumper conversion, custom ZL-1 grille, halo harness, Painted silver stripes, GM GFX, black painted lower edge of skirts and rear bumper. MGW shifter.....and now a 3.91 1LE diff
07-08-2014, 09:25 AM | #14 | |
Drives: 2010 2 SS Join Date: Oct 2013
Do you see any issues with heat soak on the MAF with the CAI brand? Anyone actually take temps inside the CAI box vs the actual engine compartment? Does the inside box temp become irrelevant inside the tube that goers into the TB? |
