![]() Drives: 2012 Camaro SS Join Date: Feb 2013
Stability/Trac Service Light
Needs some help guys! My Stability/Traction Control light came on in my car about a few days ago.
![]() ![]() 1. Can't turn it off with holding the button for 7 secs. 2. Just stays on all the time 3. I've done and checked everything including the coils to the spark plugs. ![]() It's a 1LT RS V6 Any other ideas? Or just send it to the dealer? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Have you had it up on a rack (oil change, etc...) or any wheels off or any other service recently?
COTW 5/06/2013
Drives: 2017 Corvette Grand Sport-Ho-Vette Join Date: May 2012
Tires recently?
![]() ![]() ![]() ![]() ![]() Drives: 2012 SIM 2LT/1970 Camaro Join Date: Nov 2012
Go to a local auto parts store and see if they read codes for free. Find out what it's complaining about.
All bleeding stops eventually -- 2012 2LT Auto w/sunroof -- My journal thread
Roto-Fab Intake & W/W Relocate Kit -- ADM Race Scoop -- Dynomax VT Axle-Back Exhaust -- Vitesse Throttle Controller RX Catch Can -- Drake Bowtie Delete -- JacFab Radio Face Cover -- LED Fog Lights -- LED Dome/Trunk/Plate Lights -- Gen5DIY Dash ABL -- Diode Dynamics Cupholder Lighting Wishlist: ACS T5 Splitter -- Hood Vent Mod -- Footwell/Door Pull/Homelink Button Lighting |
#5 | |
I held the Trac control for about 30 seconds and the lights came off but only stayed off for about 2 seconds. |
#6 |
#7 |
No, and I'm not sure it'll generate a code, but it's something free to try before paying the dealer to check it.
#8 |
Is your new wheel/tire combo close to equal circumference front and back?
If the diameter of the front set and back set was only close, but have gotten too far apart with tire wear, that will set off the Stabiltrac. It might be worth the trouble to look underneath and be sure the fragile ABS sensor lines haven't gotten into harm's way too. Also a dirty MAF will trigger it as well. A can of cleaner from the auto parts store is cheap and easy to use, and not a bad thing to add to your routine maintenance. You may want to try that before dealing with an appointment etc... |
#9 |
![]() Drives: 2011 2LT/RS/M6 Black w/ Orange Guts Join Date: Feb 2011
hey i just had this problem with my car. went to the dealership about 5 - 6 times they said they had it fixed everytime but the light kept coming back on and going off. Apparently my speed sensor wire was chafing and mis positioned (My dealership did my lowering springs as well) ask them to check your speed sensore wire / sensor positioning maybe it will be an easy fix
#10 | |
I'll check the undercarriage tomorrow as we'll. Thanks for the tips
2012 LS3 SS, Zl1 Spoiler, 21" Hot Wheels Edition Rims, Pirelli 245/40R21 & 275/35R21, OEM Ambient Lighting |
#11 | |
Thanks
#12 |
Back from the dealer! As Vgav1221 said, freaking speed sensors! My front right was disconnected apparently and it made the computer shoot lots of codes!
Check the speed sensors guys!
#13 |
im glad i could help you!! took me about 9 visits to my dealership + a whole bunch of cussin and pulling my hair out to figure out what it was.
