Old 07-07-2014, 02:29 PM   #1
Skylane765
Skylane765's Avatar
Drives: ZL1-1LE, Z/28
Easy fix for brake fluid cap leaking
What I did on my ZL1 and Z28 is just use a spacer to get the bladder tighter on the tank. It worked like a charm! No more brake fluid leak. This pick is my truck, but the Camaro is the same cap. Use a old school door handle washer, or any other thin material.
Skylane765 is offline   Reply With Quote
Old 07-07-2014, 04:05 PM   #2
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
What did you use for a spacer?
2017 ZL1 M6 Bog City, 2013 ZL1 M6, 2010 2SS M6
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 07-07-2014, 04:08 PM   #3
strych9
I'll be back...
strych9's Avatar
Drives: Subaru, HD Road Glide Special
There is a TSB that replaces the entire reservoir for this problem. Fixed mine after different caps were tried.
Bye bye, Bumblebee!
Old 07-07-2014, 04:36 PM   #4
Skylane765
Skylane765's Avatar
I just used a door handle plastic washer, like off a 55 Chevy, you can even make one out of any plastic like a milk carton. I found this to be way less time then taking to the dealer and changing it all out. I rather work on my own car for little things like this. Yes new caps do not help even a new reservoir may not help. I have a new reservoir on the Z28 and it leaked, after using the washer it stopped it forever.
Old 07-07-2014, 04:41 PM   #5
Skylane765
Skylane765's Avatar
Yes, new caps will still be loose. Even new tanks may leak, I have a new tank on the Z28 it leaked. The caps are just too loose.
Old 07-07-2014, 10:15 PM   #6
Alfieboy
Madman
Drives: 2017 1SS
great idea
Alfieboy is offline   Reply With Quote
Old 07-08-2014, 12:13 AM   #7
Red Jewel RS
Red Jewel RS's Avatar
Drives: 2010 Camaro 2SS
Cool. Thanks! I'll give it a try.
Red Jewel RS is offline   Reply With Quote
Old 07-08-2014, 02:18 AM   #8
jayno20
Go fast, please.
jayno20's Avatar
Drives: 2019 Corvette ZR1
was this still an issue on the 2014's?
jayno20 is offline   Reply With Quote
Old 07-08-2014, 02:23 AM   #9
Midnight Rat
Midnight Rat's Avatar
Drives: SS 1LE
He did the mod on his z28. It was leaking.
Midnight Rat is offline   Reply With Quote
Old 07-08-2014, 08:37 AM   #10
jbotta
jbotta's Avatar
Drives: Camaro ZL1
Mine was leaking around the seams and the cap.
Dealer changed my reservoir, Notice the leak around the seams.
Was a simple fix, Took about 1/2 hour.
jbotta is offline   Reply With Quote
Old 07-08-2014, 10:40 AM   #11
Skylane765
Skylane765's Avatar
Yes, the cap we think is loose for people that never check fluid and push the bladder back up, so it's loose to let the bladder suck down in the tank.
No it does not leak around the seams, the fluid just drains and stays on the seams.
There are just not to smart mechanics at dealers that think it leaks at the seams.
Old 07-08-2014, 10:45 AM   #12
Skylane765
Skylane765's Avatar
Better and easy, faster fix and will never leak is add the washer.
Old 07-08-2014, 10:41 PM   #13
KaBoom1701
KaBoom1701
KaBoom1701's Avatar
Drives: 13' ZL1 Red M6
I hate this...ever time I track my car I get some leaking around the reservoir.
I even swapped my V6 one for a V8 SS brake cylinder and reservoir and it still leaks.
What washer can I buy and install to fix this?
Mods:
Old 07-08-2014, 11:13 PM   #14
L99CAMA2011
L99CAMA2011's Avatar
If you have an Advanceauto store near you just get the GM replacement cap that doesn't have the logo. All I had to do was shave the inside groves and walah. Never leaked since.
