Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-11-2014, 05:22 PM   #1
2013zl1guy
Drives: 2013 ZL1 M6
Michelin PSS, which version (not size) to choose?
Looking at getting 295/35R20 and 315/35R20 but there are so many versions.
See attached images highlighting the major differences. 3 choices for the front and 2 choices for the rear.
What are people buying from the available choices?
Some of these figures don't make sense, like tread width being wider than section width. I've seen a couple threads talking about rubbing, not sure if it is related to these different tread widths. I'd like the K2 rears just because of the extra tread depth.
2013zl1guy is offline   Reply With Quote
Old 07-11-2014, 05:51 PM   #2
HDRDTD
All I can tell you is I have the K1-105Y's on the front and I love them.
Old 07-13-2014, 08:33 AM   #3
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
I would like to know too.
2013 ZL1 #7860 is offline   Reply With Quote
Old 07-13-2014, 11:10 PM   #4
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Check this out. Looks like the Ferrari spec tires are built a bit differently than the non Ferrari spec tires:
http://f10.5post.com/forums/showthread.php?t=682188
2014 ZL1, manual trans, carbon hood insert, Rotofab, Pacesetter 1 7/8" headers, 1" drop BMR springs, stock pulleys, 91 octane tune, 545rwhp & 515rwtq
Serviced and modded by Cordes Performance.
2011 C6, 750rwhp, forged LS3, ported LSA heads, Vortech Ti-trim, 227/243 115+4 Lunati cam, ported LS3 intake, Alky Control methanol, Pfadt sways/shocks/trans mounts, Pfadt tri-y headers(Sold 6/28/14)
jon6.0 is offline   Reply With Quote
Old 07-13-2014, 11:13 PM   #5
So Cal Camaro
So Cal Race Team
So Cal Camaro's Avatar
Drives: 2013 Camaro
Yup, that is why I run the Ferrari spec tires...Michelin PSS are not created all the same...
So Cal Camaro is offline   Reply With Quote
Old 07-13-2014, 11:28 PM   #6
jon6.0
Going for Plaid
jon6.0's Avatar
Drives: 2011 C6
Which versions do you use? K1 or K2 for the rear? 105Y or 101Y for the front?
Old 07-14-2014, 12:17 PM   #7
2014CamaroZL1
2014CamaroZL1's Avatar
Drives: 2014 CRT ZL1
Correction to my original post:
I wanted maximum width, so I went with:
K1 (105Y) on the front - 0.4" wider than the 101Y.
K2 on the back - 1½" wider than the K1 and greater tread depth.
However, I do get the occasional rub in the front (& back) on stock wheels & suspension.
Next time, I will go with the K1 (101Y) front and K1 rear.
2014CamaroZL1 is offline   Reply With Quote
Old 07-14-2014, 02:48 PM   #8
pumpkinrancho
COMPULSIVE CAMARO OWNER
pumpkinrancho's Avatar
Drives: 18 ZLE,14 2ssrs,96,73 RS LT,69&67
I have the k1 105ys front and the K2 rears. No problems other than the tire guys wihining as they are wide. Grip is light years ahead of the F1gen2s. Not even close. 1 autocross to date and they did well. Me not so much. Both Ferrari spec.
Old 07-14-2014, 05:51 PM   #9
2013zl1guy
Drives: 2013 ZL1 M6
Looks like I'll be going K1 105Y for the front and K2 for the rear. I'll risk the potential rubbing issues. so far 2014CamaroZL1 is the only one I've seen that has had issues with it, and it doesn't sound to be too major.
Old 07-14-2014, 06:05 PM   #10
More-Gas
More-Gas's Avatar
Drives: 2014 1SS 1LE
Sounds like a good setup. Did you need to change the camber setup or you using the factory alignment. Notice any handling changes or understeer?
More-Gas is offline   Reply With Quote
Old 07-15-2014, 08:56 PM   #11
97ChameleonTA
97ChameleonTA's Avatar
Drives: 2013 ZL1 Convertible
I just put these on although with 285's in the front. The rears are K2's the fronts don't have a K designation. No problems at all.
2013 ZL1 Auto Convertible - BRM
Best: 10.829@127.15
FI Interchiller, Roto-Fab CAI, Big Gulp & Res, 9.1/2.5 Pulleys, PB&S, DeatschWerks 1500cc, Fore triple pump, Pfadt LT's, RD HX, MT DR's
New times to come with E85
2016 2SS Auto - Hyper Blue Metallic
Roto-Fab CAI
97ChameleonTA is offline   Reply With Quote
Old 07-16-2014, 03:42 PM   #12
pumpkinrancho
I have not changed the alignment specs from stock. Goodyears sucked but wore out flat so all is good.
Old 07-16-2014, 03:46 PM   #13
Sven59
HAMMER PILOT
Sven59's Avatar
Drives: 13 ZL1#182, 85 CJ7, 16 Silverado
The tire guy told me the main difference was tread depth, the k2s have a little more tread.
"DO YOU WANT ME TO PUT THE HAMMER DOWN?"
Sven59 is offline   Reply With Quote
Old 08-04-2014, 09:17 AM   #14
2014CamaroZL1
My original post #7 corrected.
