07-12-2014, 07:34 AM | #1 |
Drives: 2010 Black Camaro SS Join Date: Dec 2012
L99 XPipe
I already have an SLP loudmouth I axelback which is basically a muffler delete. I recently got an xpipe that is very similar to the magnaflow tru-x crossover pipe. I cant tell the difference. I am going to delete the resonator and put the xpipe in. I am sort of aware of the AFM, can't people get used to it or get a range device. What should I expect?
Is it going to be noticeably louder? I'd like to be louder Deeper tone? Is it worth it to be installed?
2010 2SS/RS Upgrades: SLP Loudmouth I axle back / Vararam Intake / TSW Mugello Rims / GM Heritage Grill / Ghosted Oracle Side Markers /Tinted Windows and Tail lights
07-12-2014, 07:54 AM | #2 |
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM Join Date: Oct 2010
It will be slightly louder. The more airflow you have the louder your exhaust will be.
It wont be crazy loud over the resonator, but will help with airflow. |
07-12-2014, 08:11 AM | #3 |
Drives: 2010 Camaro 2SS Join Date: Jun 2014
Yes it's a little louder, but more of a deeper, throaty sound than anything. I love it. I HIGHLY recommend the range device. Sounds like garbage when it drops to 4 cylinders. Can pick one up on here for < $150
07-12-2014, 09:38 AM | #4 |
Distributor of Liquor
Drives: My Wife Crazy Join Date: Aug 2011
The x-pipe helped mine with rasp. Didnt kill all of it but killed quite a bit of it. And to be honest with you I don't think the X pipe will make your setup louder. It evenly distributes the airflow better through the dual exhaust than the H pipe does. Because of this the exhuast sounds a little more mellow if that is the right word for it.
Before I got my X pipe I had the stock H pipe with a muffler delete. While my friend had X pipes with the muffler delete. Mine was louder and more aggressive sounding while his was more of a deeper growl |
07-12-2014, 01:34 PM | #5 |
Drives: 2010 camaro SS Join Date: Jun 2014
so with an X pipe does it bolt on to your headers or does it require you get it welded on?
2010 CGM 2SS
Blackwing SLP CAI TSP 2" LT headers 1.25 pfadt lowering springs 18x10 Forgestar CF5 all four ZL1 Front conversion Tune |
07-12-2014, 10:02 PM | #6 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Depends on which one you get. The Magnaflow True X is welded on, as is their resonated version. A couple of the others can be bolted on.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
