Old 07-14-2014, 03:59 PM   #1
Bongo
Drives: 2014 ZL1 Ashen Gray Metallic
Advise for coming off the line?
Lately I've been spinning really bad and getting partly sideways or else spinning all the way through first gear and through part of second gear coming off the line. Anyone know a technique to help with that?
2014 Camaro ZL1 - Ashen Gray Metallic
Recaro Performance Seats
Sunroof
Carbon fiber hood insert
20" Machine faced wheels
20% Tint
Bongo is offline   Reply With Quote
Old 07-14-2014, 04:40 PM   #2
Emvici
Drives: 2014 ZL1 White Convertible
launch control
Emvici is offline   Reply With Quote
Old 07-14-2014, 05:38 PM   #3
CanadianZL1#992
ANGRY Z
CanadianZL1#992's Avatar
Drives: 2015 Camaro ZL1
Auto or manual ????? Stock tires or drag radials ???
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
CanadianZL1#992 is offline   Reply With Quote
Old 07-15-2014, 04:57 PM   #4
Bongo
Originally Posted by Emvici View Post
launch control
I seemed to spin even more with traction control on. Its an Auto and I was using stock tires since I haven't had time to go out and get any DR yet.
Sunroof
20% Tint
Old 07-15-2014, 05:11 PM   #5
SPOOKYGUNNER
ROCK
SPOOKYGUNNER's Avatar
Drives: 2013 ZL-1 TRIPLE BLACK VERT
Drop your tire pressure. Start at 25 psi and go down 1 psi
I run 18-20 psi in my drag radials. Stock tires should hook better with less than stock pressure.
WHEN ONE AMERICAN IS NOT WORTHY TO BE FOUND...THEN WE AS AMERICANS HAVE LOST. POW/MIA YOU ARE NOT FORGOTTEN
SPOOKYGUNNER is offline   Reply With Quote
Old 07-15-2014, 06:03 PM   #6
Camarodriver2
Camarodriver2's Avatar
Drives: FOR SALE! Bumblebee 1 of 1
Sorry to jack the thread..with no ZL1. I read that they were all tuned for factory performance, no wheel spin. Missing something?
My 1 of 1 Bumblebee: Paint=House of Kolor Sunrise. Shaved door handles and concept handles added. Shark fin removed, concept mirrors, Showstoppers concept LED side marker lights. Wiper blades removed, muffler delete, and Range AFM disable. BMR springs lowered 1" rear and 1.4" front and added Eibach wheel spacers - 20mm rear and 25mm front.
Camarodriver2 is offline   Reply With Quote
Old 07-15-2014, 06:11 PM   #7
2013 ZL1 #7860
Drives: 2013 ZL1 A6 #7860
Is this a joke? 580 bhp, you are going to have traction issues that need to be managed, no different than in an SS with 430 bhp. Just because the traction control system helps keep the car under control doesn't mean it makes it hook all the time without wheel spin.
2013 ZL1 #7860 is offline   Reply With Quote
Old 07-15-2014, 08:28 PM   #8
Lotsafn
ASHEN ZL1
Lotsafn's Avatar
Drives: 2013 ZL1 Ashen Grey Vert
That is so true. 580 hp does and will spin the tires even with the traction control on. It's all about how hard you mash the peddle and the surface your driving on. Your tires will definitely have a lot to do with it.
Lotsafn is offline   Reply With Quote
