Old 07-18-2014, 09:14 PM   #1
edgehead2000
2016 Camaro 1LT 2.0T
edgehead2000's Avatar
Drives: Nemesis
Delete
Delete, sold
edgehead2000 is offline   Reply With Quote
Old 07-20-2014, 08:27 PM   #2
edgehead2000
Drives: Nemesis
Bump
Old 08-20-2014, 10:31 AM   #3
lincoln361
lincoln361's Avatar
Drives: 2011 Camaro SS/RS
pm sent
SLP TVS 2300- 1 7/8 LG Headers- RDS NX Plate- 75 Shot- No Cats- SLP Loudmouth 2- NW102- 3.8 Pulley- OD Cog drive-12lbs boost-FIC 80# injectors-ZL1 Fuel Pump- RotoFab CAI- Apex CAI Scoop- Pat G Tune- Weld RTS drag pack- BMR Trailing Arms- BMR 1'' Drop Springs-BMR Lower Control Arms- BMR Toe Rods- BMR Rear Cradle Bushings- BMR Upper Control Arm Bushings- BMR Extreme Anti- Rollbar- Hotchkis Subframe Brace- Prosport Evo Boost & F/A Ratio
lincoln361 is offline   Reply With Quote
Old 08-20-2014, 11:46 PM   #4
SparkyDL75
SparkyDL75
SparkyDL75's Avatar
Drives: 2010 Camaro 2SS/RS CGM/Grey
How did the tires perform in dry conditions? I tavoid wet weather so I'm not really worried about wet performance. I am considering getting a set when they finally release the 305/35r20 sizes.
2010 CGM 2SS/RS M6 LS3 Black/Gray
Exterior American Racing BLVD Black w/Machined(20x10) Mickey Thompson Street Comps(275/40 & 305/35)
Suspension Pedders Pace Car Pkg w/ZL1 Upgrade; Pedders Upper & Lower Control Arm, Steering, & Differential Mount Bushings; Pedders SS Brake Lines; Pedders Dual Bearing Camber Plates; ZL1 Toe Link; Hawk Performance Ceramic brake pads
Drivetrain Maggie2300(8psi-3.4pulley); CompCam; 85lb injectors; ZL1 fuel pump; ZR1 MAP; Centerforce DYAD Twin Disc clutch; Stainless Works LT headers; QTP Cutouts; Rotofab intake; RX catch can; Mike Norris tune 643rwhp 598 rwtq
SparkyDL75 is offline   Reply With Quote
Old 08-21-2014, 09:22 AM   #5
lbheat
Echale Gas [COTW 3/10/14]
lbheat's Avatar
Drives: 2010 Camaro SS/RS Supercharged
These are badass! One of the best I have ran on my car.
Kenne Bell
502 rwhp/ 471 rwtq at 9psi (daily driver...for now)
Performance: Corsa catback, JRE Super Tensioner, dual pass heat exchanger, R1 slotted & Dimpled rotors cryogenically treated
Cosmetic: Giovanna kilis 22", zl1 mailslot bumper, Custom Emblem Pro Badge, painted calipers
lbheat is offline   Reply With Quote
Old 08-21-2014, 06:47 PM   #6
lincoln361
lincoln361's Avatar
pm sent again
Old 08-21-2014, 11:06 PM   #7
edgehead2000
Drives: Nemesis
The tires are great for dry conditions, on a couple cruises around NM this summer they hugged the road more as they got warmer.
At the moment, I only want to sell all 4 tires as a set.
Old 08-30-2014, 10:34 AM   #8
edgehead2000
Drives: Nemesis
Still available! $600 obo
Old 08-30-2014, 03:18 PM   #9
lincoln361
lincoln361's Avatar
Pics?
Old 09-01-2014, 07:47 PM   #10
SlowmaroSS2
SlowmaroSS2's Avatar
Drives: 2010 Camaro SS2
Would you sell just the rears?
SlowmaroSS2 is offline   Reply With Quote
Old 09-01-2014, 10:06 PM   #11
dishonored
dishonored's Avatar
Drives: 2012 Camaro SS/RS
If he will I might be interested in the fronts.
dishonored is offline   Reply With Quote
Old 09-27-2014, 12:25 PM   #12
edgehead2000
Drives: Nemesis
PM's being sent to you two guys for splitting the set
Old 09-28-2014, 10:06 PM   #13
ZuluKilla8
ZuluKilla8's Avatar
Drives: 2010 Camaro 1SS/RS RJT
Also interested in the fronts if willing to split
2010 Camaro SS LS3 Holley Hi-Ram Manifold,Custom grind boost cam,Vortech V-3,10Rib 3.47 Pully Airfilter Pipe Delete, 10 PSI, TSP LT Headers, Flowmaster Outlaws, Alky Control Meth Kit, PFADT 1.25, ZL1 Fuel Pump, DSS 1000HP axles, Mantic ER2 Clutch, Full BMR rear suspension drag pack upgrade. C6 Vette 18 rims with M/T 305 out back. COPO Hood
Race Proven Motorsports tuned
ZuluKilla8 is offline   Reply With Quote
Old 10-01-2014, 11:17 PM   #14
edgehead2000
Drives: Nemesis
Sold, please delete
