Old 07-21-2014, 10:53 PM   #1
jsg1518
Drives: none yet
Question on 1le
Does this car only come in 6spd or is auto an option like the zl1.
jsg1518 is offline   Reply With Quote
Old 07-21-2014, 10:55 PM   #2
Slimmy909
Drives: 2014 SS CAMARO 1LE
Only 6 speed manual
Slimmy909 is offline   Reply With Quote
Old 07-21-2014, 10:56 PM   #3
BlueAc
BlueAc's Avatar
Drives: Acura TL (for now)
M6 only
BlueAc is offline   Reply With Quote
Old 07-21-2014, 11:05 PM   #4
jsg1518
Drives: none yet
Thanks. Dumb question, I just read the other post. Sorry
Old 07-22-2014, 10:19 AM   #5
gajagfan
gajagfan's Avatar
Drives: 2013 1SS 1LE Black - Std Exhaust
And even though you did not ask, thought you might like to know that it is a different M6 than is in the standard SS. That seems to be misunderstood here a lot is why I mention it. Sorry if you did not need this.
gajagfan is offline   Reply With Quote
Old 07-22-2014, 10:51 AM   #6
Mark T
American Gold Whisperer
Drives: 2014 White 1LE 2SS/RS/NPP/Rec/Nav
To expand,..
6-speed manual only
SS 6.2L engine only
ZL1 suspension components only
limited options, seats, nav, sunroof, and exaust,... only
Bottom line,... fun,... only
Mark T is offline   Reply With Quote
Old 07-22-2014, 03:17 PM   #7
X25
X25's Avatar
Drives: '16 C7 Z51
Originally Posted by Mark T View Post
To expand,..
6-speed manual only
SS 6.2L engine only
On a side note, sunroof reduces the headroom quite a bit, so it might reduce your fun when you wear a helmet : )
'16 Corvette C7 Z51 1LT (Build Thread)
'14 AGM 1SS 1LE [COTW 11/17/14] (Build Thread) (SOLD)
'13 Mazda MX-5 Club (Build Thread)
'17 RAM 1500 Crew Cab 4x4 Night Edition
'15 Nissan Rogue S AWD
X25 is offline   Reply With Quote
Old 07-22-2014, 06:32 PM   #8
fatboy99
fatboy99's Avatar
Drives: 2014 Camaro 1LE
: this is true
fatboy99 is offline   Reply With Quote
Old 07-23-2014, 01:39 AM   #9
Camaro Dude
Camaro Dude's Avatar
Drives: ‘13 1LE
+1
Ordered mine with no sunroof.
Sunroof was a deal breaker, I don't fit in 'em.
Ditto on the CTS-V Coupe. No go period.
Camaro Dude is offline   Reply With Quote
Old 07-23-2014, 10:57 AM   #10
Schluney
Schluney's Avatar
Drives: 2014 2SS 1LE
+1 on sunroof my parents have a L99 with a sunroof and its crazy how much less head room it has
14 2SS RS 1LE Recaro NPP Pat G cam and tune, Trick flow heads Long tube headers catless
Schluney is offline   Reply With Quote
Old 07-23-2014, 06:52 PM   #11
sinisterZL1
sinisterZL1's Avatar
Drives: 2014 ZL1 - M6
To expand,..
6-speed manual only
SS 6.2L engine only
The 1le dose not use the same suspension as the zl1. The zl1 uses magnetic ride control and the 1le uses monotube struts but does use the same electric steering. Also the following-
Larger, 27-mm solid front stabilizer bar, and 28-mm solid rear stabilizer bar for improved body control
Higher-capacity rear-axle half shafts to cope with increased levels of traction
Strut tower brace for improved steering feel and response
ZL1-based 20 x 10-inch front and 20 x 11-inch aluminum wheels
285/35ZR20 Goodyear Eagle Supercar G:2 tires front and rear (identical to the front tires for ZL1)
ZL1 wheel bearings, toe links and rear shock mounts for improved on-track performance
ZL1 high-capacity fuel pump and additional fuel pickups for improved fuel delivery during high-cornering
2014 ZL1 Auto - 4L80e, Magnuson 2650 , Sleeved LSA 376 , Forged Bottom , LPE Ported Heads , FI Chiller , 991 RWHP, 877 RWTQ
sinisterZL1 is offline   Reply With Quote
