Old 07-22-2014, 01:51 AM   #1
redleader
redleader
Drives: 2010
Wheel Spacers
I think my wheels need to come out, spaced further out, to line up more flush with the body, as they look a bit factory... so...
What Spacers do I need?
Where do I get them? What specs?
Do I need longer wheel studs?
What about tracking and alignment?
Are there ride issues?
Are the turning arcs of the wheel in the wheel well OK with this?
Are there power or fuel effects?
2010 1LT V6 Camaro
1.2" BMR drop springs
2013 20", 245 front, 285 rear
Thanks,
redleader is offline   Reply With Quote
Old 07-22-2014, 04:19 AM   #2
Ph3lix004
Drives: 2014 Camaro
Sub'd for info too
Ph3lix004 is offline   Reply With Quote
Old 07-22-2014, 08:51 AM   #3
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
Check here- http://www.camaro5.com/forums/showth...=wheel+spacers
Old 07-22-2014, 08:59 AM   #4
redleader
redleader
Drives: 2010
Originally Posted by Ventmaster View Post
Cheers ! :-)
Old 07-23-2014, 06:56 PM   #5
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
I have H+R 25mm all the way around.
Eddiefuzz is offline   Reply With Quote
Old 07-24-2014, 12:26 PM   #6
c5Legend
Camaro5
c5Legend's Avatar
Drives: 2010 Camaro 2LT
I was worried about putting spacers/adapters on my car because of all the bad reviews online.. but I ended up buying some (for a different car) and putting it on there.. they weren't even name brand they were like 45$ a piece and worked well (I believe they were aluminum and were thick as hell).. No difference in driving at all and no shakes ect.. Car is a daily driver seeing about 60-70 miles a day..
I would recommend getting spacers/adapters that comes with new threading to be on the safe side.
So don't be afraid when you come across folks bashing on spacers.
My Build
'11 Chrysler 300 Limited / '10 Camaro 2LT
c5Legend is offline   Reply With Quote
Old 07-24-2014, 01:46 PM   #7
redleader
redleader
Drives: 2010
Cheers Guys! :-)
Old 07-24-2014, 05:58 PM   #8
Sikoriko
Sikoriko's Avatar
Drives: 2011 V6 IOM
The more the tire sticks out the more junk will get thrown up on your fenders, then you'll need mud gaurds, just my 2 cents
Old 07-24-2014, 07:15 PM   #9
JohnZ
JohnZ's Avatar
Drives: 2010 Camaro 2LT V6
Im curious, is your car also lowered? If so, have you had any rubbing issues?
Injen CAI, V-Max Throttle Body, Rx 25mm Iceolator, Rx 10mm Plenum Spacer, Mace Ported Manifold, ARK N-II Catback, Trifecta Tune, Rx Catch Can.
BMR Bushing Inserts,Pedders Radius Rod Inserts, Pfadt Sway Bars and Endlinks, LSR Front Subframe Brace
SS Brembo Brakes, Racing Brake Stainless Lines
JohnZ is offline   Reply With Quote
Old 07-25-2014, 07:48 AM   #10
redleader
redleader
Drives: 2010
Good point!
Mine is lowered, BMR 1.2"
Old 07-25-2014, 07:55 AM   #11
2010SLVRBULIT
2010SLVRBULIT's Avatar
Drives: G5(LLT) & C6(LS3)
Had adapters that pushed the factory RS rims out 1" on all corners and it looked nice(flush w/ the fenders), along w/ a 1" Eibach drop. Only time it would rub along the tire shoulder was when I had rear passengers + large bump.
Old 07-25-2014, 07:26 PM   #12
Eddiefuzz
Eddiefuzz's Avatar
Drives: 2011 RS
I have ZL1 springs which lowers about 1/2 inch, but there isn't that much travel, and with the 25MM the tire sits just inside the wheel well. Where I park my car for work is a long dirt road, so I've had Huskey splash guards for a while now. Take a look in my album in my profile,I have many photos.
