wht different between the LS3 and L99
I wanna know wht different between LS3 and L99overlod performance and part of the engine if I wanna modified it thank you
CaMaRo FrOm HeLL |
![]() ![]() ![]() ![]() ![]() Drives: ... Join Date: Oct 2008
I can tell you a little........damn little..........the L99 comes with 400hp automatic and the LS3 has 426 hp and a manual or "stick".
The L99 has a fuel management system that helps or is supposed to with fuel management but what do I know............I'm getting a V6 |
Custom User Title
Drives: Fast Join Date: Jan 2009
LS3 - 426HP - Manual Transmission
L99 - 400HP - Automatic Transmission with active fuel management (AFM turns 4 cylinders "off") You can modify the hell out of these engines, from exhaust to a supercharger. Nobody knows the peak HP output of this engine (before modifying internals), but the block can handle tons of psi. |
Thank you very much for info
did any one modify the engine of ls3 or l99 (internal )
CaMaRo FrOm HeLL |
I know ADM PERFORMANCE (aka Andy) already took his motor out and put a 427 with a few mods and it is kicking over 600 horses in his bad asze Camaro.
You can check out his posts and see what he has done. It is pretty sweet. I saw and HEAR it last Saturday. Ck out his thread http://www.camaro5.com/forums/showthread.php?t=36712 Last edited by a6pk2go; 08-12-2009 at 04:37 AM. |
#6 |
![]() ![]() Drives: 2009 GMC Yukon Join Date: May 2009
Not another thread like this.
#7 |
![]() Drives: 2010 Camaro Join Date: Jul 2009
Dude these threads are the best! Great unintentional comedy
Imperial Blue SS![]() |
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 RY 2SS with Custom Stripes Join Date: Mar 2009
What is the milage differance on the sticker between the L99 and the LS3?
#9 |
Camaro SL,UTs
Drives: 2010 Camaro SS/RS #16429 Join Date: Sep 2006
The L99 comes with 3.27 gears and the LS3 has 3.45.
L99 = 10:4 compression LS3 = 10:7 compression
#10 |
Moderator.ca
They use the exact same engine block and the vast majority of other pieces, so what you can do to one you can do to the other. The main difference between the two engines is that the L99 has variable valve timing and active fuel management.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#11 |
USN CPO
Drives: 08 Titan,2103 Challenger 392 SRT-8 Join Date: Nov 2008
the heads are different because of the afm system, and a small cam because of the afm, and as others have said it also has vvt, but if you changed the cam and heads it would be an LS3, you would also need to the ecm reprogramed to turn of the afm.
Montrose
2013 Challenger SRT8, Auto, PCP. mods, Diablo Sport Trinity T1000, AAD catch can, Mopar strut brace, MBRP S7102304 cat-back, MM 85mm TB.
08 Titan PRO4X Gray. |
| LS3 engine specifications | Tran | Wiki | 3 | 10-06-2010 11:56 PM |
| LS3 vs L99? | SGOS252382 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 34 | 09-18-2010 04:55 PM |
| Check your Order here | bvonscott | Camaro Price | Ordering | Tracking | Dealers Discussions | 665 | 06-29-2009 02:00 PM |
| Tuning LS3 vs L99 | Evilangel | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 17 | 10-30-2008 11:22 AM |
| L99 engine specifications | Tran | Wiki | 0 | 10-19-2008 12:40 PM |
