07-23-2014, 08:13 PM | #1 |
Drives: 2011 2SS Join Date: Jun 2013
will belt slip be an issue
I am going to be upgrading to a blower cam and then OD cog setup on the rear of my Maggie I want to run around 8-10# of boost once I swap cams so I think I will be using either a 3.8 or 3.6 from pulley with OD rear so my question is with these larger pulleys still getting good belt wrap and lower boost 10 or less will I have an issue with belt slip?
2011 2SS,fti th400, ECS 1500, Flex Fuel, Boost built 376, squash fuel system
07-24-2014, 10:35 AM | #2 |
2010 Lingenfelter SS
Drives: 2010 lingenfelter ss Join Date: Sep 2013
I would say your gonna see belt slip. I have a innovators west 8 rib setup complete with a jre super tensioner for sale. Has 300 miles on it. $1500 for complete kit with 3.2 pulley.
2010 ss, forged 376 ci bottom end with diamond pistons, 640 lift comp cam, 260cc prc heads, fast 102 with nw throttle body, full exhaust, f1 - a pro charger powder coated all black, alky dual nozzle meth kit, monster twin disc clutch, dss driveshaft and axles, 391 gears, full suspension, 20' rohana rc22 wheels, 305/35/20 m/t DR, 840rwhp.
07-24-2014, 01:13 PM | #3 |
Drives: Black 2SS Join Date: Oct 2009
I'm running a cam, OD cogs with a 3.6 front pulley and the JRE tensioner and have not had any problems.
07-24-2014, 03:42 PM | #4 |
whippled 5th gen
im over 10 lbs with no belt slip, but have the innovators west 8 rib with 10 percent overdrive balancer.
07-24-2014, 03:53 PM | #5 |
Emerald Coast Camaros
Drives: 2010 RS/SS Rally Yellow & 68 SS Join Date: Dec 2012
Don't know about the Maggie. But am running 12LB on the whipple with a 6 rib and 13LB when meth is used 3years and close to 400 passes with no belt slip
Best @ 586/525 =10.41 @ 133
AS OF 12/13/14>633 RWHP =10.22@135 AS OF 1/31/15 @ 633 RWHP=10.16@135 AS OF 1/29/16 @ 633 RWHP=10.10@136 TOPED 700 PASSES AFTER F.I. AND STILL ON THE ORIGIANAL STOCK AXLE & DIFF |
07-25-2014, 02:22 AM | #6 | |
Slowhawk Built
Drives: 2010 Supercharged SS Join Date: Apr 2014
9.21 @ 149 Slowhawk Performance
07-25-2014, 06:43 AM | #7 |
Cool thx I don't really want to spend 300 bucks on a tensioner right now
07-25-2014, 07:17 AM | #8 |
Slowhawk Built
Tensioner would be nice but you have max belt wrap so you'll be fine. I spun a 3.4 6 rib with no slip.........10.5 psi (stock cam).
07-25-2014, 12:44 PM | #9 |
Drives: Z28 Join Date: Dec 2013
You shouldn't, but you could step it up to a green fleet runner belt if you do, they stretch less.
07-25-2014, 09:57 PM | #10 |
Cool thx for info do U know part numbers on that belt or where to get it
07-28-2014, 09:55 AM | #11 | |
Without the JRE supertensioner belt slip will be a problem. Ted.
www.jannettyracing.com
08-02-2014, 06:37 AM | #12 |
Drives: 2012 ZL600 Camaro Join Date: Oct 2012
Belt Slip
I ran nearly the same set-up and had belt slip until I installed the JRE tensioner.
