![]() Drives: Camaro Join Date: Dec 2013
Halo Harness from Gen5DIY
Has anyone else purchased this product for their ZL1? I bought the harness for my 2013 ZL1 and my Halos now are always on when I drive, however my DRL's no longer turn on when I drive. Is this normal? Or is it a problem with mine?
DiabloZL1
![]() Drives: 2015 ZL1 Join Date: Jul 2014
Pardon my ignorance, remember my car hasn't arrived yet, when are the halos on? I thought they were always on already
DiabloZL1
![]() Drives: ZL1 2012 # 721; 2013 Tahoe Z71 Join Date: Feb 2012
The Halo harness does not tie to the DRLs at all. Goes from a switched fuse in the fuse box to the headlamp plugs and supplies power to the halos whenever the ignition is on.
If your DRLs are not on during the day you have a problem with the DRLs. for automatics the car has to out of park for DRLS to come on For manuals the E-Brake has to be off for the DRLs to be on. |
#6 |
I never knew about the e-brake and the DRL's before. My car is either in a garage so i can't tell when i start the car because the lights turn on, and my drive way is slanted so my e-brake is on. Thanks for the info guys, everything works fine!
| Tags |
| gen5diy, halo, harness, zl1 |
