Old 07-26-2014, 09:48 AM   #1
Slowp0ke
Drives: 2013 Camaro ZL1
is this suppose to look like this?
https://www.flickr.com/photos/pruffolo/14562042318/
https://www.flickr.com/photos/pruffolo/14768545853/
I was over looking my ZL1 and something looks off, is the shock towers suppose to be this far from the body?
Slowp0ke is offline   Reply With Quote
Old 07-26-2014, 09:52 AM   #2
motorhead
That's normal
Old 07-26-2014, 12:10 PM   #3
vatechguy3
Drives: 2014 ZL1 M6
Mine looks just like that.
Tony
2014 ZL1 M6
Bone stock, for now!
2001 Z28 M6
!cags, !air, FTP 85mm Lid, Z06 85mm MAF, P&P TB
!4x4, Strano Springs, Strano Sways, Koni 4/4s, Watts Link
ARH LTs, ARH catted Y, SLP catback with Dual/Dual Muffler, SLP CME and Valance
OE Wheels Machined Face C5 DDs, 18x10.5s, with 295/35-18s on all 4 corners!
352rwhp and 366rwtq
vatechguy3 is offline   Reply With Quote
Old 07-26-2014, 12:18 PM   #4
ZL1-V
When you snapped the photo can you remember if had your wheels turned at an angle?
ZL1-V is offline   Reply With Quote
Old 07-26-2014, 12:55 PM   #5
Slowp0ke
straight and flat ground
Old 07-26-2014, 12:56 PM   #6
Slowp0ke
ok thank you for clearing that up for me guys
Old 07-26-2014, 01:11 PM   #7
Featherburner
11 Sec. Bolton car.
Featherburner's Avatar
Drives: 09 G8 GT
Just because it is common doesn't mean it's normal. I would venture to bet you have a collapsed strut mount.
09 Pontiac G8 GT 11-second bolt-on car
Featherburner is offline   Reply With Quote
Old 07-26-2014, 04:52 PM   #8
Baer383
Drives: 2013 ZL1 Ashen Gray
Baer383 is offline   Reply With Quote
Old 07-26-2014, 04:57 PM   #9
Mpsmith1
Mpsmith1's Avatar
Drives: '19 ZL1 1LE
Originally Posted by Baer383 View Post
+1
I just went outside to check mine. It looks exactly the same.
Good question, though....
Mpsmith1 is offline   Reply With Quote
Old 07-26-2014, 08:27 PM   #10
I call it Vera
Drives: ZL1 Convertible
mine looks like that also, and I do not believe I have anything wrong with my car.
I call it Vera is offline   Reply With Quote
Old 07-26-2014, 10:08 PM   #11
AMMUSCLE
AMMUSCLE's Avatar
Drives: 2013 ZL1 VERT M6
That is normal.
You can have someone sit in the car and turn the wheels back and forth and they will move.
So no worries.
JANNETTY RACING 750 ROUGH IDLE CAM PACKAGE
(681 RWHP & 643 RWTQ) = 783 CRANK HP & 740 CRANK TQ
AMMUSCLE is offline   Reply With Quote
Old 07-26-2014, 11:06 PM   #12
Featherburner
11 Sec. Bolton car.
Drives: 09 G8 GT
Yeah, maybe the Camaro is different than the G8 based on the same platform. I'm sure you are right, it's fine. http://www.g8board.com/forums/showpo...5&postcount=19
Old 07-26-2014, 11:15 PM   #13
jessrayo
Speed Freak
jessrayo's Avatar
Drives: 2013 ZL1 Camaro, 2016 Camaro SS
I could see that being the problem if one side looked like that and one side was down flush. That may be the case on a G8. On my ZL1 both sides look just exactly like the OP's pics and they have since the day I got the car. I thought it looked a little crappy when I first noticed it also but at this point I'm kind of used to it. I have looked into getting camber plates to change the way that looked but all of the camber plates I have seen to date require you to dispose of the magride front shocks and I love the magride more than I hate that little gap. May be problem on some other make. ZL1 it is normal.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date.
jessrayo is offline   Reply With Quote
Old 07-26-2014, 11:18 PM   #14
Featherburner
11 Sec. Bolton car.
Drives: 09 G8 GT
Like I said, maybe it's different on the Camaro.
